[Z06] check engine lite help??
my check engine lite came on right after I filled up with shell vpower 93, I reseated the gas cap but nothing happened, lite still on, any other suggestions? do you think it is just the gas and i should run it until it is empty? mileage around 15000 no problems before this. thanks for the help.
You might get the light if the Gas cap was not put back on correctly and tightened properly. However, sounds like you already covered that end, could have been a bad tank of gas from the station, perhaps some water got into the mix. Hope you get to the bottom of it.
Good Luck.
Good Luck.
ago the light came on. I did the usual: checked the gas cap, ran it
until empty and filled up with a different brand, etc. The light stayed
on. I finally took it in for a checkup at the dealer, and it has a cracked
right side gas tank. So, you might want to check if you smell gas near
the rear wheels just in case. Good luck...
BTW, it takes 7-10 working days for the dealer to get the tank. I'm
still waiting...
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I . Read and post the DTC codes!! that way we can point you in the right direction. i seriously doubt that filling it up or bad gas had anything to do with the code!
BC
BC
Location: Probably talking that police officer out of giving you a summons! ========== The Beautiful Lower Hudson Valley, NY
St. Jude Donor '08-'09
Originally Posted by VetteZ16
You just threw a code. Maybe you just ran a little lean. No Big deal just reset, I sure you will be fine.
Charlie
BC
BC
