[Z06] z06 shift fork question
does anyone know if an 02 z06 has alum or steel transmission shift forks. anyone had trouble with the shift forks in an 02 z06 ?. i have heard of problems with the alum shift forks in c5 coupes & verts. thanks steve
Originally Posted by Scott03Z06
The shift fork change (from Al to Steel) was around mid-03 production so I'd say you most probably have Al forks.
My 02' had aluminum shift forks and when I got my tranny rebuilt, under warranty, they put a steel one in it.
St. Jude Donor '10-'11
Anyone know the Vin # changeover to Steel forks in '03?
I've been around the circle on this question several times. Appears the change was sometime in Dec /02/ - Jan/03. Consensus is that it was after the FFS fuel system change. However, no one has been able to come up with the definitive date or VIN.
Originally Posted by MrHiPerf
to have your shift forks upgraded to steel? And what should it cost?
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
1 Post
Originally Posted by slwhite
I suppose that my 02 has aluminum forks but I have not had any trouble with the transmission or anything else for that matter. The car has 22,000 miles.
Cruise-In IX Veteran
Originally Posted by megavettes
If you don't mind me asking, what does it cost to have the synchros replaced? Thanks!
Originally Posted by zo6vetteman2003
I have an early 03' ZO6 had all of them replaced with steel.
Any thoughts would be apprecitated. Cheers.
Neil
Neil,
I would address the reverse lockout with whoever fixed your tranny. It can be fixed without removing the tranny (could be the solenoid is not reconnected). Otherwise, a good dealer tech can fix it.
Z06_Bob
Z06_Bob
Aaaarrgg
I can tell you that My 02 HAD the Aluminum I just dropped it off at the Dealer cause It was stuck in between 3rd & 4th Thank Goodness for GMPP it wont cost me a Dime.. But I tell ya what nothing better than sitting in rush hour grinding gears looking like A Rookie trying to FIND a gear it will go into
Originally Posted by Z06_Bob
Neil,
Z06_Bob
Z06_Bob
