[Z06] LG G5X3 cam
LG G5X3 cam
Im doing a little bit of reading to get ready when I pull the trigger on a cam. I want a big cam but not going to replace the heads. I dont want to lose the ability to drive the car on like a 1hr or 2hr drive. Would this be to large of a cam? Where cam I read up some more on all the specs and what all the numbers mean exactly.
Thanks did a search and found some good info. When im ready im gunna do the G5X3. What have some cars with this cam and long tubes and bolt on's run in the 1/4.
I have an 03 z06 and was wondering if anyone knows of a good tuner in the NC area. I live in Charlotte and am looking into putting a new cam in. The G5x3 looks promising and I hear many good things about it, but I don't know if I can't find a good tuner within a few hours from here.
Car is not a daily driver mostly worried about highway. I have 9k miles in 2 and 1/2 years on the car,
Thought about the gears also. Thanks I still have some time before I pull the trigger. Thanks again.
Oh, and I wish you were closer to Chicago so I could tune yours! lol
Later I picked up an 04 GTO...and the fun began.
Going with the Cam - Only theme...
G5X3 on 114
921 Springs
SW Headers
RT Cats
Stock 243 Castings - Non Ported
Tuned with Lou G's input
The cam was rowdy with quite a bit of reversion...but pulls like a train.
If left to idle for a long time, the 02s would make it rich.
Otherwise, the car would idle down the Dallas North Tollway at rush hour without a hiccup.
Keep in mind, it will not run when you first install.
After 3 weeks of daily driving with HP tuners on board and 1 hr on LGs dyno...
Here you go
http://www.horist.com/hptuner/
Search 04 Pontiac GTO and scroll down til you see LG G5x3. Your tune is done. Pick up the cam!!
Originally Posted by Closer_2001
Back in the day...I had an 02 Black / Mod Red Z and drooled over Godspeeds's Cam only X3 Posts...
G5X3 on 114
921 Springs
SW Headers
RT Cats
Here you go
G5X3 on 114
921 Springs
SW Headers
RT Cats
Here you go
That doesn't help him decide if this cam is good for his needs....and it's very cryptic. Besides you really should have had the right length pushrods in there for correct rocker angle. I can't believe Lou didn't stress that to you. That's why these cams are kitted in the first place.
So I have a few questions:
Why didn't you just use a better link instead of making us search?
Why do you think your GTO tune will be compatible with his Vette?
What's to say this is a correct tune?
The point is not that it can or cannot be tuned. Is it right for his needs.
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
THE LGM G5X3 cam on a 114 lsa is the perfect performance cam that is still very streetable for stock headed LS6 and LS1 cars for that matter. Just get the complete CAM kit from LGM as suggested by Mr. Cowl Hood and make sure that a professional who knows what he's doing both installs and tunes your car (on a dyno) and you will be a happy camper!
2022 C2 of the Year Finalist - Modified
I'VE SEEN POSTS ABOUT CAROLINA AUTO MASTERS IN DURHAM, NC.
IF YOU TRY THEM, LET ME KNOW HOW YOU LIKE THEM. I'M THINKING ABOUT THE SAME SETUP ON MY 2003 Z.
BY THE WAY, I'M IN MOORESVILLE, NC
I just recently purchases the MS3 from TSP (237/242 .603/.609 on a 113lsa). One of the major reasons i chose this over the G5X3 is that with this cam i actually know the specs. LG is to cams like Roswell is to aliens.
Originally Posted by NeverT00Fast
You'll def. get good results from that cam. I got 460+rwhp using that cam and a set of budget heads with all bolt-ons but no 90/90.
I have an 04 Z with the G5x3 and it is my daily drive. I use to have 4.10 gears in the car and it was perfect. But I broke those gears at the track last nov. now I am back with the 3.42's. I can say that around town the 4.10's took all of the cam surge out and was very easy to drive around town. With the 3.42's its a little different. I drive in traffice about 45 mins each way. You just need to make sure your RPM's are above 1500 and you will be find. My best 1/4 time was 11.5 @ 124 mph with a 1.72 60'. I know I could have gotten more but after the last rearend brake no more hard launches for me.
