Old 02-20-2015, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
[Z06] Clutch Pedal Woes--Fluid Impact
Old 10-06-2012, 02:18 PM
  #121
0jhaines
Former Vendor
jhaines's Avatar
Default Clutch return spring
As others have mentioned, the OEM spring found in the pedal assembly of the C5 and C6 Corvettes is not a clutch pedal return spring. It is an over center spring. It assists on one side of the travel and resists on the other side of the travel.
The Lingenfelter clutch pedal return spring kit for the C5 and C6 Corvette (PN L360080197) is, as the name implies, a clutch pedal return spring. As many have found, under some conditions the pedal will not return after a shift. This usually happens under high RPM driving conditions. The clutch pedal return spring solves this problem. We offer a similar kit (PN L360091410) for the 5th Gen Camaro and 2nd Gen CTSV.
If you look at a production 2012-2013 ZL1 Camaro, they have a clutch pedal return spring built into that clutch pedal assembly (in addition to the over center spring). I have attached an image of the ZL1 Camaro pedal assembly with the two springs labeled. And, no we didn't copy the ZL1. We had our clutch pedal return spring out at least a year before the ZL1 came out - just two different groups of engineers coming to the same solution. 8-)
Since the C5/C6 Corvette, the 5th Gen Camaro (other than the ZL1) and the 2009-2013 CTSV don't have provisions for a clutch pedal return spring, you need more than just a spring. You also need a bracket to attach the spring to. Our kits for these applications include:
  • a CNC machined billet stainless steel bracket with fasteners that mounts to the clutch pedal assembly to secure the spring on one side
  • a stainless steel spring with an outer dampening sleeve (to reduce the noise from the spring)
Here is a link to the installation instructions that include some pictures.
Several have mentioned our product as the "$90 spring". Keep in mind you aren't paying $90 for just a spring. A stainless steel CNC machined bracket and mounting fasteners are also included. In addition, the spring is a stainless steel spring with an outer dampening sleeve to reduce noise. We have also done a fair amount of testing to determine the proper spring length and rate for the application so you don't have to test out 20 different springs from the hardware store and then worry that you are yielding the spring and going to have it fail 2 weeks later.
Due to the increased sales of these parts, we have been able to reduce the cost of the brackets by making them in higher volumes so we have recently reduced the price on the clutch return spring kits to $79.95 for both versions.
Originally Posted by fatlt1
make a thread and ask about the 90 dollar spring. i personally know a few guys with c6 z06 and they run the spring and no issues, i myself like the tick unit. the spring helps the pedal not stick to the floor simple as that, brings the pedal back up faster preventing it to stick to the floor.
http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
Old 10-07-2012, 05:53 PM
  #122
Cruncher
Cruncher's Avatar
Originally Posted by Ranger
I'd suggest checking the fluid every time you fill up with gas. Any time you see that the fluid is even slightly murky, then change it every few days until its remains clear. The reservoir holds about 3 oz., about 20% of the entire capacity of the clutch hydraulics. By doing this you are keeping the average freshness much higher and ridding the system of debris before it accumulates.
The procedure is:
(1) Draw out the funky fluid with the syringe. Picture of Syringe
(2) Wipe out the reservoir with a paper towel.
(3) Refill with fresh fluid to the fill-line.
That's it. Takes about three minutes. Take care to keep the (corrosive) fluid off your paint. I dispose of the spent fluid in a sealed container.
Some folks find this procedure too much trouble. But other that follow it avoid pedal issues that are MUCH more bothersome.
Ranger
I used to do the above procedure...it took about 5-10 minutes. Then one day, a service tech showed gave me a TSB addressing the dark brake fluid in the reservoir. The dark color had to do (this is off the top of my head) with rubber and the TSB stated that the brake fluid in the clutch reservoir should not be changed. If you want more info, I'll go find the TSB.
Old 10-09-2012, 12:30 AM
  #123
orangeclaw
orangeclaw's Avatar
broken spring (clutch would stick)
took it out and havnt replaced it yet.. dont know if i will.. clutch has not stuck once yet.. and i drove her pretty good this weekend
Old 10-09-2012, 02:42 PM
  #124
fatlt1
fatlt1's Avatar
yup u can try that as well, i mentioned it prior on my post earlier. i did that as well on my fbody car and it solved the issue. that be a good starting point without spending any money for sure just remove the spring completely. i liked it in my fbody, it gave the pedal and little stiffer feeling which i like. but on the z06 i just wanted to replace it with a overall much better hydraulic system than the factory piece. i love the tick performance clutch master cylinder probably one of the best things ive done to this car by far. the car shifts and drives a difference by night and day.
Old 10-09-2012, 07:31 PM
  #125
zeevette
zeevette's Avatar
Don't you people read posts other than your own?
Old 05-18-2014, 04:10 PM
  #126
ilovelespauls8
1st Gear
ilovelespauls8's Avatar
hello Ranger
i have done what you said to do and the problem is still there but it is better than it was but it still comes back after about an hour of driving the car what would do you think i need to do at this point
oh and the fluid is clear with very little color change
thanks
Old 05-18-2014, 08:14 PM
  #127
racebum
racebum's Avatar
Originally Posted by ilovelespauls8
hello Ranger
thanks
not sure if he still checks these
but
i've been in your shoes and can tell you what happened with my car
when i bought my z the fluid was black. shifting under power was the same problem everyone else has. i did the ranger method, slight improvement, then i kept doing it every tank of gas for the first year i owned the car. that's probably 20 flushes over 5k miles. it's MUCH better now
Quick Reply: [Z06] Clutch Pedal Woes--Fluid Impact
