[Z06] VIDEO at Idle plus streetability and WOT with my 511rwhp / FTI
The ETP milled to 60 cc :
The ETP 215 intake side :
The ETP 215 exhaust side :
The ETP prepared with the upgraded FTI PS4 Valve Springs :
The Cometic head gasket from Ed 4.030 by 0.040 :
The ARP Pro-Series Head Bolts :
The StreetSweeper :
The adjustable timing chain to match the requirement on the IVC :
The Morel Billet Hydraulic Roller Lifter:
The Three Pieces Pro-Series Heavy Wall Push Rods (8.100) :
The Upgraded Harland Sharp OEM Rockers :
The Melling High volume Low pressure oil pump :
The Powerbond Underdrive Pulley 25% :
The 90 FAST Intake (Tony Mamo ported) with the IAT Sensor relocated in :
A view of the IAT sensor inside the FAST to fit my OLSD tune :
The LS2 TB (Tony Mamo ported) :
The LUCAS 42# Injectors Flow-match and ingraved (assigned by cylinder) :
The Injector Data Sheet for the Injector test (to 10 000rpm...) :
The high flow intake filter with carbon duct without MAF :
The CAI Cover isolated with thermoaluminium product :
The LG Pro Longtube Headers (without cats) :
LOST THAT PICURE...
The SPEC Stage II plus matched balanced to the OEM Flywheel :
The SPEC Aluminium Flywheel :
My Christmas Box full :
My Christmas Box ready that was sent to J&J Performance :
LOST THAT PICURE...
Hi ctusser,
Yes it is the OEM LS6 that came in my ZO6.
As I had a rering under extended warranty just before my last mods, I decided to upgrade the Rod Bolts to the KATECH one.
Other of that everything is OEM here and the pistons didn't required any flycut !!
Christian
Christian
#33
CI 3-5-6-7-8 Veteran
^ What oil pressure are you seeing with the melling?
Hot idle?
Hot cruise?
I put an LS4 pump in mine and whith 5w40 Amsoil I'm seeing 49psi hot idle and 57ish hot cruise.
Hot idle?
Hot cruise?
#34
You can check that in the second video named drivability, I just did it and the oil pressure gauge is clearly visible.
Number showed at 900 rpm oil mini 200° ~ 40
Number showed cruising at 2000 rpm oil mini 200° ~55
With the Melling the pressure goes up quicker than the OEM LS6.
I have the low tension spring in the Melling.
Christian
#35
Thats a perfect formula for a great performer. Fantastic how fast it got to 180's range. I really think a new Z isn't worth my o4 Z and a lot of money. I would take your post to a good tuner and say just do this. Best post and videos I have seen for a long time. Did I miss what mufflers you have ? Maybe stock titanium?
#36
YES OEM Titanium,
The idea was to be able to drive in town with no cops stopping us every minutes, presently my wife sometime goes shopping with the Z, and the exhaust still has a nice sound when going WOT.
Inside the noise level is acceptable cruising along, like I say, the car is wild and tame...
Christian
#37
