[Z06] Z06 vs FRC
Old 12-28-2007, 01:33 PM
NVR KNO
NVR KNO's Avatar
Default Z06 vs FRC
I was wondering since the 99/00 FRCs were practically the 01-04 Z06s, did they have the same drivetrain too? I know the FRCs had the LS1s and the Z06s had the LS6s, but did the FRCs have the M12 like the Z06? Or just the M6 like the other C5s? Suspension the same as well?
Old 12-28-2007, 01:39 PM
Z06Fix
Z06Fix's Avatar
The FRC's didn't have the M12 tranny or the Z06 suspension. I am pretty sure all of them came with the Z51 suspension.
Old 12-28-2007, 01:44 PM
NVR KNO
NVR KNO's Avatar
Yea I knew they had the Z51 suspension.... As an option right? But heard from a few people they thought it had the M12 tranny as well. The Z06s have the FE4 suspension....
What about the gears in the FRC vs Z06? FRC has 3.42s and the Z06 has 3.90s.... right?
Old 12-28-2007, 02:49 PM
Z06Fix
Z06Fix's Avatar
Both the FRC and Z06 had 3.42 gears in them. The M12 tranny just has shorter gearing in it than the M6 found in the FRC and coupe.
Old 12-28-2007, 03:02 PM
Mr. Azrael
Mr. Azrael's Avatar
FRC has the Z51 suspension standard. FRC has the LS1, MN6 transmission, and the regular 3.42 rear end (found in the MN6 coupe).
Z06 has the FE4 suspension, LS6, MN12 transmission, shot peened 3.42 rearend (added strength). The MN12/3.42 combo accelerates a Z06 like a coupe/FRC with ~3.90 gears due to more aggressive internal gearing in the transmission. Z06 cars also have the lighter glass...
Old 12-28-2007, 03:51 PM
NVR KNO
NVR KNO's Avatar
Ok.... I didnt understand that part when I read it. So the more aggressive internal gearing in the Z06 makes it pull like a Non-Z06 with 3.90s.... Gotcha. Thanx for clearing that up. I did know about the lighter glass.
Old 12-28-2007, 05:37 PM
Thud
Thud's Avatar
The C5 convertibles with HUD also had the same (lighter) windshield as Z06's... GM likes to reuse parts wherever they can.
Incidentally, the C6 vettes with Z51 also have the same gear ratios as the C5 Z06.
Old 12-28-2007, 06:24 PM
NVR KNO
NVR KNO's Avatar
Guess thats why theyre close in performance then....
Old 12-30-2007, 02:21 PM
dieseldave56
dieseldave56's Avatar
Default Read ; differences between FRC and Z06..........
Just read these post form earlier this year; http://forums.corvetteforum.com/show...post1559289058
Old 12-31-2007, 01:48 AM
NytmereZ
NytmereZ's Avatar
What he said to a tee
Old 12-31-2007, 02:50 AM
patjza80
patjza80's Avatar
honestly if I were in that position and depending on price you could always swap parts if you were willing to do work. Do some heads and a cam and you'd probably make more power than a Z06. I personally went with a Z06 because its a "Z06" but its all up to you. Its all what you want. IMO.
Old 12-31-2007, 08:08 AM
NVR KNO
NVR KNO's Avatar
Well I already bought a 01 Z06, so.... I was just seeing what the differences were between them. Wasnt exactly sure. Thanx for the info though.
Old 12-31-2007, 08:42 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
The FE4 suspension consists of a different shock package and one end has a different spring rate and different swaybar, but I can't remember if it's the front or rear. I want to say the Z06 has a stiffer rear spring and a larger front bar which would mean the front spring is the same as the Z-51 and the rear bar is the same, but I'm not 100%.
Old 12-31-2007, 08:50 AM
BillY2KFRC
BillY2KFRC's Avatar
You are correct!
To Z06 vs FRC
Quick Reply: [Z06] Z06 vs FRC
