[Z06] What brake pads to stop the brake dust blizzard?
Old 02-03-2008, 03:03 PM
civlant
civlant's Avatar
Default What brake pads to stop the brake dust blizzard?
So I've come to the conclusion that after only 25 miles of driving my gray wheels are already covered in brake dust (fronts). I refuse to be like the typical BMW owner that drives around with black front wheels and gray rear wheels. What pads do you guys suggest? I'm sure the ones on there are stock being that I only have 27K miles.
Old 02-03-2008, 03:07 PM
rudyarias
Support Corvetteforum!
rudyarias's Avatar
You bought a Z06 not a waxer C5. The stock pads are dusty because they are performance pads. You can swap them out with ceramics and be fine on the street. Personally, brake dust is a sign that the car been driven
Old 02-03-2008, 04:28 PM
MVR 155
MVR 155's Avatar
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Funny way to put it and I agree..... I however had to swap my stock pads for ceramics since I bought the CCW wheels (polishied aluminum and the stock pads dont mix one bit). I have my stock stuff sitting in a box to be quickly installed should the need arise ie: track day.
To the OP, the ceramics are more than adequate for street duty and if your over driving them on regular city streets/highways you seriously need to consider getting on a track before you injure yourself or someone else...... not saying you drive like this or intend to...... simply saying the ceramics are fine for street duty.
Old 02-03-2008, 04:38 PM
wildwall
wildwall's Avatar
Hawk Ceramic Pads
Old 02-03-2008, 06:45 PM
chimazo
chimazo's Avatar
The Delco/GM ceramic pads also do a nice job reducing dust.
Old 02-03-2008, 07:35 PM
Bob CTS
Bob CTS's Avatar
My Delco ceramics really reduced the dusting.
Old 02-04-2008, 08:01 AM
BlackZee06
BlackZee06's Avatar
Delco ceramics are the way to go unless you're going to do track time.
Old 02-04-2008, 08:26 AM
floyd66
floyd66's Avatar
I Agree hawk ceramics 80% less dust . And they stop great.
Old 02-04-2008, 08:30 AM
civlant
civlant's Avatar
Well I don't intend to track the car so I'm just looking for pads with good stopping power. Now how much "worse" at stopping are the hawks than the stockers? Some of you guys make it sound like I would take a lot longer to stop (the track comments)?
Old 02-04-2008, 08:41 AM
only59
only59's Avatar
Historically Ceramic pads can be noisy, is that the case with the Ceramic pads mentioned above ?The Noise would bother me, the dust doesn't.
Old 02-04-2008, 08:43 AM
SweetZO6
SweetZO6's Avatar
Default Hawk HPS Pads
I installed the Hawk pads with great results. They brake better then the GM OEM pads and generate significantly less dust. I got the best of both worlds with them.
Ed
Old 02-04-2008, 08:50 AM
mark896
mark896's Avatar
AC Delco DuraStops
Old 02-04-2008, 09:06 AM
MVR 155
MVR 155's Avatar
You probably wont notice any reduction in stop distance on the street (unless you were coming down from well into the triple digits)... the track comments are made because ceramic pads tend to fade after repeated hard braking (typical to what you subject them to on a road coarse). For street duty the ceramics are more than adequate, I have the GM ceramic pads and they work great, virtually no dust and they have yet to make a sound (squeal).
Old 02-04-2008, 04:33 PM
wildwall
wildwall's Avatar
When I put the new pads on, I also changed the rotors. I found on ebay a
company that drills and slots Brembo rotors and powders coats the center hub red. I think the set of four cost about $300 and the hawk pads ran around $200. I couldn't see putting expensive pads on old rotors. The hawk instructions explain that if the rotors aren't new, you have to sand the surface so the pads bed properly. Needless to say the brakes look awesome drilled and slotted with red hubs to match the calipers!
Old 02-04-2008, 04:39 PM
civlant
civlant's Avatar
Installed pic?
Old 02-04-2008, 05:29 PM
wildwall
wildwall's Avatar
Installed pic?
don't have one. Will take one tomorrow. I also bought stock style chrome wheels with Vredersteen tires. I can tell you that dust is no longer an issue, period. The only dirt on the wheels now is road dirt.
Old 02-04-2008, 05:37 PM
Eddie 70
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have been wanting to change to ceramic pads for a while now just for this reason. I drive mine every day and sometimes cannot wash my care every week and the brake dust on the wheels really builds up after 2 weeks of daily driving. My son put ceramics on his camaro with Z06 wheels and the dust is almost a non issue anymore.
To What brake pads to stop the brake dust blizzard?
Quick Reply: [Z06] What brake pads to stop the brake dust blizzard?
