[Z06] Are C6 Z06 shocks better than 2004 Sachs Z06?
Old 04-27-2008, 07:22 AM
californiakid
californiakid's Avatar
Default Are C6 Z06 shocks better than 2004 Sachs Z06?
I have the 2004 Sachs shocks and I will be doing some tweaking of my suspension, would going to the C6 Z06 shocks benefit me or should I do a T1 shock upgrade? I do do some DD events at Hockenheim from time to time.
Thanks,
Californiakid
Old 04-27-2008, 11:19 AM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Most cannot tell the difference between the 04Z shocks and the 06Z shocks, so I doubt it will benefit you. The next step would be the T1's for you.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 04-28-2008, 09:43 AM
Z06Fix
Z06Fix's Avatar
T1 shocks are setup for the T1 bars and springs. I would keep your 04's unless you are upgrading everything. They are a very good middle ground shock.
Old 04-28-2008, 10:40 AM
Over-torque
Over-torque's Avatar
if you were needing to replace worn stock shocks? would the 04Z or 06+ Zs be a better shock for a daily?
Old 04-28-2008, 10:57 AM
meldog21
meldog21's Avatar
I'm not an expert but by reading a whole lot of posts here about GM shocks it appears the C6 Z06 shocks are about the same as the 04 C5 Z06 shocks. The big difference is the price. C6 shocks are about half the cost of C5 shocks.
Dog
Old 04-28-2008, 09:29 PM
dagon138
dagon138's Avatar
I think the jury is still out on the 04Z06 vs C6Z06 shocks, one was designed for the C5 Z06, the other was not.
I'd personally spring for pfadt's new adjustable shocks if I was in your shoes.
Old 04-29-2008, 07:18 AM
Joy of 6
Joy of 6's Avatar
Dog
I've got the C6 Z shocks on my 02 Z and like them quite well. There is not that much difference in the C5 - C6 suspension that you could tell a difference. I would bet that only Ron Fellows could tell the diffference in the shocks. Go for the C6's. The T-1's as mentioned are designed for the full T-1 suspension upgrade and you should do it all or none.
To Are C6 Z06 shocks better than 2004 Sachs Z06?
Quick Reply: [Z06] Are C6 Z06 shocks better than 2004 Sachs Z06?
