[Z06] LS6 oil capacity
c5 zo6 oil consumption
that is high, could be the old ringset.
a quart every 1000 miles isn't usually enough to create carbon build up, at least not quickly, and that's how oil burning can blow up motors. if the exhaust valves and ringlands get coated in it, they will eventually frag
the worst part about a quart every 1000 miles is what it does to the cats. excessive oil use can damage and potentially melt cats as the oil gets trapped and lights up in the cats
i would try 5-40w motor oil and see if it improves at all
Z06 oil capacity
When I refilled the oil after the first oil change on my 97 it took 7 quarts to get it to the same point on the dip stick. My LS6 took 6.5 quarts to fill to the full mark on the dip stick but I always throw in the extra half quart. Unless the garage pumps the oil into the car from a drum the charge for 6.5 quarts is the same as 7 quarts (you have to buy 7 containers either way).
Bill
Bill
But at the end of the day you have to know your car's mod's. I have a 2006 Z06 with a lingenfelter high capacity tank for the 2006 Z06 to solve oil starvation at high G tracks like Pocono and Daytona. I also added a large front oil cooler, (Swedish rally unit), that also added 1 quart so I take 11.5 quarts. I always check the levels after an oil change carefully to make sure we are at the right level.
I hope this helps,
VRZ06
