[Z06] do i need to remove my rear brake duct for 305 tire???
Old 12-01-2008, 07:39 PM
carlsbad
carlsbad's Avatar
Default do i need to remove my rear brake duct for 305 tire???
Old 12-01-2008, 07:45 PM
ptindall
ptindall's Avatar
No. I've got 315s and the tires clear the ducts fine.
Old 12-01-2008, 08:47 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
No issues with my 305-30-19's here in the rear.
Toque
lubranjo
lubranjo's Avatar
315s here also and NO issues...
Old 12-01-2008, 09:02 PM
94brick
94brick's Avatar
thats odd I had to remove mine for 305/35/19 's...
Old 12-01-2008, 09:16 PM
speedyhawk101
speedyhawk101's Avatar
taller tire may be why
Old 12-01-2008, 09:17 PM
itsphoenix
itsphoenix's Avatar
I had to remove the pass side but not the driver side.
Old 12-01-2008, 09:23 PM
RonVette2
RonVette2's Avatar
Didn't have to do anything with mine, 305/30/19's here
Old 12-02-2008, 12:20 AM
butchvette
butchvette's Avatar
St. Jude Donor '09
Default 325s rear tire
i have 325/30/19s did not rub but very very close to wall inside (3 credit cards) i have the z07 wheels from corvette garage. also can be lowered on stock bolts but you have to play with it as far as rubbing inside. but it looks freakin ffffaaaaattttttttt. and i still have the the ducts.
Old 12-02-2008, 12:28 AM
richsblackz06
richsblackz06's Avatar
I just put 305/30/19s with no issues. I also have the car lowered about an inch, I think you'll be fine.
Old 12-02-2008, 12:39 AM
Blue Blood
Blue Blood's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
No problems 305/30/19 Michelin PS2, with only the slightest rub on the inner tub but ducts are fine.
Old 12-02-2008, 11:20 AM
THE TECH
THE TECH's Avatar
No rubbing on my 305 Michelin Pilot Sport Cups.
Old 12-02-2008, 11:37 AM
jmc12
jmc12's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Same as above with my car 03-Z same tire and sizes...
Old 12-02-2008, 01:11 PM
Z06Fix
Z06Fix's Avatar
I've got lots of room with my 315's on. Alot of autox guys are running 335's with no issue either. Atleast with the brake duct.
Old 12-02-2008, 01:40 PM
royski
royski's Avatar
Default rubbing
i put nitto,s 305 dr,s on my 02 z06 and they rubbed on the brake ducks just a little . i used a hair dryer and pushed the plastic in a eight inch or so that cured it did not remove ducks .
Old 12-11-2008, 10:51 AM
JPennyZ06
JPennyZ06's Avatar
Default Brake Ducts
I had to remove the brake ducts for my 305-30-19 Bridgestone Potenza RE050 As, they tend to run a bit wider than the other 305 tires. I recently put CCW SP500s on my car, 19x11.5 in the rear with 325-30-19s Goodyears. Needless to say, I decided to take a chance and replace them with the Nitto Invo 345-30-19s. Discount Tire and a few other forum members told me they were about the same width and height.
Let me say, I couldnt be happier with them, they look great and hook well! And suprisingly, they dont stick out that much, maybe a 1/4" to a 1/2" at the most!
Old 12-11-2008, 11:04 PM
NOLA
NOLA's Avatar
Im lowered on stock bolts and have 305 nitto dr's and no rubbing.
To do i need to remove my rear brake duct for 305 tire???
Quick Reply: [Z06] do i need to remove my rear brake duct for 305 tire???
