[Z06] WEldcraft Wheels C5Z 18X12
Weldcraftwheels.com These guys did an awsome job. I am very happy with the customer service and the craftsmanship looks top notch. I weighed the wheels and they are both at 23.4lbs. Not bad for a 18x12"
Nice work.
Let us know how they balance after you put rubber on them.
Is this for street tires or track tires?
Do you have a minitub?
Reason I ask is I run 18x12 CCWs in the rear for track. I've seen this wheel widening process. Wondered how well they balance after, will take to road course abuse, and fit a 335 without a minitub. My 18x12s have 335 Hoosiers on them and with 1/8" spacer they just barely clear the inner fender liner.
Graham
Graham
Nice work.
Graham
Graham
wheel america in dallas also will do this and they use one weld. basically they take a back half off a viper wheel I think and weld it to the Z wheel I had them repair a crack and the work was top-notch
Ohhhhh so nice
I'm getting James and company to widen a pair of 19x11 Z replicas out to 12 as we speak. Once I get them back, I'll have them refinished to match the front OEM argent.
How are they working out for you?
I dont beleive they widen the C5Z wheels on the outside, I got ahold of them a few months back about doing that and they said there wouldn't be enough for a safety bead, and they couldn't do it.
removing the top of the Pass would not be a good tidea IMO. I'm thinking there is just one pass, One inside and One outside That is.
Same here. I wanted the 18X10.5 that I run on the fron narrowed by about 5/8" and James said he couldn't do it.
This Guy had it done and I think James is the one that did it. The pics do not work but I do recall seeing them when this thread was first posted.
I had these wheels widened to 18x12 ". I used 2 oem z06 wheels and had them widened on the front and back to make one wheel. The front side has a 2" lip now. They balanced out nice and are light as a feather. The toyo RA's are 335/35/18 and help me greatly in getting some traction.James @ Weldcraft wheels did the work, and all I can say is he is awsome at what he does. This is an expensive project but I wanted a Z06 wheel that looked at home with my flared fender that also didnt weigh 32lbs like the aftermarket ones do. Thanks James for taking my project on
What are those pins you're using to hold the tubs down? Are those cleco pins?
http://forums.corvetteforum.com/c5-g...s-22-8lbs.html
How did you get James to take on that project for you?? I tried to get him to reduce the lip of a set up Stock Alcoas and he wouldn't do it.
I dont know, maybe after doing mine he decided it was too much involved to get the outside widened. I am greatful to him for what he was able to accomplish.
