[Z06] Oil Change = Check engine light???
Old 02-16-2009, 09:49 AM
joseph p
joseph p's Avatar
Default Oil Change = Check engine light???
Changed the oil and filter. Mobil 1 , 6.5 quarts, Mobil 1 extended life filter. No leaks, good oil pressure...next day check engine light.
Nothing appears wrong. Any ideas?
Old 02-16-2009, 10:53 AM
ptindall
ptindall's Avatar
The check engine light is unrelated to the oil change. You need to pull the code.
Old 02-16-2009, 01:16 PM
hotwheels57
hotwheels57's Avatar
Did you remember to reset the oil life monitor to 100%?
Old 02-16-2009, 02:49 PM
joseph p
joseph p's Avatar
yes
Old 02-16-2009, 02:51 PM
joseph p
joseph p's Avatar
Kinda coincidental, dontch think?
Old 02-16-2009, 02:58 PM
rbartick
rbartick's Avatar
Location: Admit Nothing, Deny Everything, Make Counter Accusations.
Stop guessing and pull the codes.
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old 02-16-2009, 04:52 PM
ptindall
ptindall's Avatar
Sort of. But just about any time you get a check engine light, you can think of something that was slightly unusual or different about the car in the previous few days. The thing is, there is pretty much nothing about a correctly done oil change that could possibly cause a check engine light enless you did something to the car you are not telling us or are unaware you did. Just pull the code and go from there.
Old 02-16-2009, 05:44 PM
GeorgeZNJ
Support Corvetteforum!
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
Old 02-16-2009, 05:56 PM
z06inVB
z06inVB's Avatar
Received 1,107 Likes on 521 Posts
I had my oil pressure indicate 80 psi and 130 psi on the DIC after an oil change. Was convinced I did something wrong..nope sending unit failure just timed wrong I guess.
Old 02-16-2009, 06:20 PM
TEXHAWK0
TEXHAWK0's Avatar
Did you put the drain plug back in?
(could not help myself)
So, what codes did you find?
Oil level sensor?
To Oil Change = Check engine light???
Quick Reply: [Z06] Oil Change = Check engine light???
