[Z06] Z06 Shifter same as coupe?
The C5 shifter used rubber isolation bushings where the "box" mounted above the torque tube.
The C5/Z06 shifter used solid metal isolation bushings, so there may be some felt vibration/noise.
In reality, the shifters from 1997 to 2009 are all the same stamped metal with rubber isolated lever design.
The only difference was the square **** that screwed onto the 9/16-18" lever for the C5/Z06 cars, and the bent back lever with ergonomic **** with side fastener of the C6/Z06 cars. The boots were also different.
