[Z06] •• LS3 into C5 Z06 Cam & Heads - results inside ••
Former Vendor
LS3 with the following;
•• RPM CNC LS3 Heads
....• 368 CFM - Intake
....• 255 CFM - Exhaust
•• RPM Camshaft
....• 230° - 236° Duration @.050
....• 114° + 2° LSA
....• .602 - .604 Lift
•• Dynatech Headers - 1 3/4" OD x 32" long primaries
•• Under drive Pulley
•• Stock Intake & TB
•• RPM Camshaft
....• 114° + 2° LSA
533 huh, .....who needs FI.
Thanks for sharing charlie.
•• RPM Camshaft
....• 114° + 2° LSA
•• RPM Camshaft
....• 114° + 2° LSA
Something you might want to consider with camshafts for engines using LS3 and LS7 cylinders heads is the fact that the intake with the large 2.16 inch and 2.20 inch valves flows significantly more than the exhaust.
Recent testing done by companies close to the General show that on engines with LS7 heads, the exhaust duration should be 20 to 22 degrees longer than the intake duration.
With these cylinder heads, the days of just 4 degrees difference between intake and exhaust duration is over.
Also, LSA should be between 116 degrees and 118 degrees.
