[Z06] 02Z alignment specs?
Going for an alignment on Tuesday, and was wondering, for a z06 that's 26 1/4'' front, 27 1/4'' rear (front bolts 2/3 bushing removed, longer rear bolts), are the factory 02 Z06 specs okay to use for street use? I searched alignments on here, and all it is is
Person A: This alignment (insert details) is the best because (insert details)
Person B: That's a horrible alignment.
etc.....
Seraching I believe these are the stock specs? (boy, that's a lot of toe in in the front, no?)
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe: +0.08 degree +/- 0.20 degree
Front Individual Caster: +6.9 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.25 degree
Front Individual Camber: -0.70 degree +/-0.50 degree
Front Cross Camber: within +/-0.25 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.68 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
etc.....
I run the factory Z specs on mine that's lowered, and they're ok. They're not as aggressive as I'd like, but my dealer gives me tires for life if they get to set the alignment, so I allow them to set it to factory specs. What are you doing for tires and wheels? If they're factory or factory sizes, there's no reason to change the alignment unless you'd like to alter the way the car reacts to your inputs.
go to pfadts coilover web page and see all settings.
http://www.pfadtracing.com/docs/camb...t-settings.pdf
