[Z06] Magnaflow 15660, too quiet...bypass mod??
I have a lightly modded '02 Z with Vararam, LG LT's, magnaflow catless x-pipe and 15660 catback. I love the tone and the looks of the exhaust but its just to quiet for me. I was reading that alot of guys like the bypass mod on the factory Ti setup so it got me thinking that it might give me the volume and keep the tone I like without costing me an arm and a leg to change the whole catback. Has anybody done this before? Even on another catback besides the stock one? Any opionions/video would be great to help me pull the trigger on modding this catback.
Thanks and Regards,
Ryan
Thanks and Regards,
Ryan
If they're designed like factory, with inlet and outlet on the same end, it should work like a charm. Never heard of anybody trying it, but since it's SS instead of Ti, there's lots less complication on the welding. Wish I'd thought of that when I had my Magnaflow CB, because I loved the deep tone. I got rid of them only because they were too quiet.
Yeah that's what I thought. It should keep the underlying tone and just intensify the volume as the rpm's increase. I might have to be the first for this...I swore I wasn't gonna go changing exhausts all the time like I did with my trans am but, what can I say, they gotta sound right. I had 12 different exhaust setups on my trans am. My friends call me the exhaust conassieur (sp?)
Did you end up doing the bypass to your Magnaflow? I'm considering doing this to my car right now with the same exhaust system but I'm unsure if it's the right choice. If you did end up doing it, were the results good?? Any drone from doing the bypass below 2000 rpm?
Sorry guys
I ended up having to sell the car. It was the best car I've ever owned or driven but the car payment and insurance for a college kid was a bit outrageous. I came out of the deal the same as I went in so I can't complain. It wasn't very long after I made this post that I sold the car so I never got the chance to mod the MagnaFlow. I still think it would have sounded badass though.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I already experience what happens with the great loud muffler experience; drone comes with it.
My Ti exhaust noise level is great to me. Yes, the bypass will give you more exhaust note, and you will be able to close them at anytime.
Modded Z06 with Magnaflow, and bypass.
Your car sounds amazing! So you had a Ti exhaust with the bypass mod and now you Magnaflows with the bypass (in the video)? Do you have long tubes installed as well?
2017 C4 of Year
Not My Z, a friend's Z at the track few weeks ago. It is a LS6 with a cam, longtubes, and the Magnacrap cat back with bypass.
Cruising
How do you close the bypass? I thought that was just linking the pipe coming into the muffler with the exit pipe coming out of the muffler with a piece of tubing welded in there? I have the magna flow as well on mine and am considering putting a set of dumps, such as the QTP, on it so I can have the option of loud or deep depending on the circumstance.
I hope you're comparing apples to apples. There are three different Magnaflow catbacks available for the C5 that I know of. That car in the race video sounds amazing, but it'd be too loud for me on the street. Yes, the standard, full size Magnaflow does drone a little, without cats, but not near as much as Stingers. Very deep tone that sounds unlike other catbacks I've heard in person. At the time I owned that catback, I had only LTs, offroad X pipe, and no partition.
Cruising
The bypass mod typically doesn't have a valve and it is just a short runner pipe to bypass the muffler like you've described. If you were to install a cutout or butterfly valve on the bypass pipe, it would function essentially the same as the GM NPP exhaust that is available on the C6 and C7 from the factory (albeit without PCM control of the valves).
I was going to install the cutout right off the pipe prior to entering the muffler and then put a down pipe on it as I think it may sound louder reverberating off the ground? Does that make sense or do you think it would sound louder straight out the rear, as in putting it in the place of the bypass pipe?
That's exactly what I thought, I am sticking to my plan of a set of electric cutouts and by the feed back I hear they are a good investment. I paid way too much for this magnaflow system to scrap it, and for what it's worth, I love the sound of my car with it on. My system is the 8" muffler though, part#16732, which I believe would sound louder than the 11" muffler(part#15660).
Cruising
If you install a typical bypass and put a cutout on the bypass, it would be quieter than if you just installed cutouts prior to the bypass. The bypass pipe is typically installed slightly off from the 90 degree bend going into the muffler, so it doesn't get 100% of the flow going through it. The developed airflow wants to follow the pipe bend but at higher rpms (higher exhaust flow rates) more exits though the bypass. If you position the cutouts prior to the 90 deg bend or if you install the bypass in line with the straight section of tubing prior to the 90 deg bend, your exhaust will sound louder. Pointing the cutouts down will allow the sound to reverberate off the ground and make it louder too like you said.
That is what I thought, thank you for your quick reply. So I guess '02 Ta this gives you some food for thought as well on a different option if you don't want to give up your magnaflow rumble.
Cruising
LOL, well I guess this is all useless for him anyhow. As for me thank you for your replies as I had someone confirm my suspicions that the car will sound better with it coming straight off the dumps rather than going straight out the back. Now to figure the best set of dumps to purchase?
