[Z06] •• DBA Brake Rotors & Hawk Brake Pads Special! ••
Former Vendor
DBA Brake Rotors & Hawk Brake Pads Package, 97-04 Corvette
Feel free to contact us with any questions. You can reach us at 205-267-6387 or seth@hinsonsupercars.com
DBA Brake Rotors
The Standard Series is DBA’s entry level enhanced performance rotor, offering improved braking straight out of the box. Available with slotting to improve pad bite and reduce brake fade. This also helps allow maximum cooling and provides an attractive, aggressive appearance. The Standard Series is the perfect replacement for performance conscious street motorists. DBA's Patented ‘Kangaroo Paw’ ventilation design is available on most popular DBA Street Series Rotors.
$274 - DBA Standard Series Slotted Front Rotors (Pair)
$294 - DBA Standard Series Slotted & Cross Drilled Front Rotors (Pair)
$206 - DBA Standard Series Slotted Rear Rotors (Pair)
$226 - DBA Standard Series Slotted & Cross Drilled Rear Rotors (Pair)
DBA's 4000 Series is their mid-range enhanced performance rotor. It features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. The unique 6x6 Wiper Slot is designed to efficiently clear dust and debris while maintaining consistent friction and a cleaner disc surface. The 4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%. Designed for the performance street and motorsport enthusiast.
$278 - DBA 4000 Series Slotted Front Rotors (Pair)
$308 - DBA 4000 Series Slotted & Cross Drilled Front Rotors (Pair)
$236 - DBA 4000 Series Slotted Rear Rotors (Pair)
$278 - DBA 4000 Series Slotted & Cross Drilled Rear Rotors (Pair)
The DBA 5000 Series is a direct replacement two-piece disc brake rotor, designed for drivers seeking performance braking. The DBA 5000 series disc rotors consists of two main components: the aluminum center hat and the cast iron disc rotor. These two components are bolted together with NAS (National Aerospace Standard) bolts and lock nuts, hence the term 'two-piece' rotor. The main advantage of a two-piece rotor (with aluminum hat), is the ability to allow the cast-iron disc rotor to expand and contract uniformly as the temperature rises and falls during brake application. The benefits of this is minimal distortion and warping of the cast-iron disc rotor. The Aluminum mounting center hat is made from super-light 6061-T6 Aluminium material, as used in aircraft structural design. The thermal conductivity and high strength of hat allows it to handle large temperature changes. The benfits of this is minimal distortion and warping of the cast-iron disc rotor. All DBA 5000 series rotors are slotted; slotting limits the possibility of glazing your brake pads and allows better 'pad-bite' under extreme braking conditions. Slotting constantly improved the disc pad friction face by wiping away the impurities and resins in the friction material. The DBA 5000 series rotors are manufactured with directional slotting, i.e. Left-Wheel disc slotting and Right-wheel disc slotting.
$674 - DBA 5000 Series Slotted Front Rotors (Pair)
$704 - DBA 5000 Series Slotted & Cross Drilled Front Rotors (Pair)
$704 - DBA 5000 Series Slotted & Cross Drilled Front Rotors (Pair) - Gold
Hawk Brake Pads
Ceramic - Ultimate stopping power in an ultra-low dust, low noise ceramic compound! Hawk Performance has introduced a premium, high performance, ultra-low dust, low noise compound called Performance Ceramic. Performance Ceramic is engineered to reduce brake NVH (Noise, Vibration and Harshness), creating a quieter performing brake pad. Furthermore, the ceramic brake pad formula has a linear friction profile that allows your ABS brake system to work more effectively. With Performance Ceramic you can expect reduced brake pad wear, lower dust output levels and a rotor-friendly brake pad. Performance Ceramic - quiet, clean & fast stopping!
$111.38 - Hawk Ceramic Front Pads
$77.06 - Hawk Ceramic Rear Pads
HPS - High Performance Street disc brake pads are world
renowned for increasing stopping power on your street legal vehicle. Increasing the performance of your vehicles braking system is easy when you choose Hawk Performance HPS braking compound. This unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology. The High Performance Street
compound offers a higher coefficient of friction over stock brake pads and can provide you 20-40% more stopping power and higher resistance to brake fade than most standard replacement pads. Less fade means you'll have a highly durable brake pad with less brake dust.
$104.76 - Hawk HPS Front Pads
$76.08 - Hawk HPS Rear Pads
HP Plus - Hawk Performance HP Plus brake pad compound is ideal for Autocross and Track Day drivers looking for a high performance race compound that can take the heat of the track and get you home safely without having to change the pads. HP Plus
utilizes a unique Ferro-Carbon, high-tech friction material that was developed and manufactured for sport driving in autocross, Solo II and track day applications. The Ferro-Carbon formulation offers lower wear rates and higher torque values than other competitive materials.
Extremely high coefficient of friction makes HP Plus the perfect upgrade over stock for high performance streetcars used in autocross competition or that experience repetitive, heavy braking.
$130.96 - Hawk HP Plus Front Pads
$100.03 - Hawk HP Plus Rear Pads
Goodridge Brake Lines
$115.95 - Goodridge Stainless Steel Braided Brake Lines (Front & Rear)
ATE Super Blue Racing Brake Fluid
$14.95 - ATE Super Blue Racing Brake Fluid (1 Liter)
Gotten any feedback on the 4000's? How long is your sale running?
Former Vendor
My post is about there not being a 2-piece rotor for the rears... I would never run a 2-piece rotor on the front and a 1-piece rotor on the rear.....
Ahhh...I didn't catch that for the rears. Interesting...
Former Vendor
