[Z06] C6 Z06 wheels fit?
Old 05-07-2010, 08:00 PM
97C5inSD
Support Corvetteforum!
97C5inSD's Avatar
But now you can also By Repo wheels in C6 design in the c5 offsets if you'd rather go that route it's the cheapest overall
Old 05-07-2010, 10:07 PM
GARB55
GARB55's Avatar
Originally Posted by 97C5inSD
These are C6 wheels on ym C5 with L5 Fenders i needed a 5/8th spacer to get the wheels to clear and keep from rubbing since my car is lowered with coilovers.
Sharp C5 Z06! Perfect Height in front and back, looking to lower mine around same height. If you don't mind like to ask you a few questions. What coil overs are you running? How do you like your Invos? What Air pressure do you run / Street / Track. Thank you for your time.
Old 05-08-2010, 08:15 AM
97C5inSD
97C5inSD's Avatar
I'm Running the DRM coilover setup. I had no issues with the invos they was a darn good street tires and even with the huge 345 rears i ran through some pretty wet roads and they held pretty darn good can't get crazy but you can still drive. As for tracking them i never did i run KhumoV710's for track and autoxing. i did autox them once and i ran a bit better time then a buddy of mine with a zo6 that was running the NTO5's but my car is setup for the kuhmos and gets horrible understeer on street tires. As for the air pressure i ran about 4 psi under the tire recommendations on the rear to help them wear more even.
I ended up selling the package after running them for a year cause there weight was just horrible at 56lbs on the rears and a bit over 50lbs on the front. And the car became a bit more Track/autox oriented and i just never got the time to drive it on the street anymore.
Old 06-12-2010, 07:19 PM
GARB55
GARB55's Avatar
Old 06-25-2010, 08:38 PM
z06sicz
z06sicz's Avatar
Got mine on today! No spacers needed. When I was under the car I noticed that there was no way these were going to fit without spacers. However when the car is in the air the wheel is closer to the vehicle. Once I lowered it I found about 1/4" of space between the fender well and the tire. Once the "A" arms compressed the tires pushed out. I love the look. Could not be happier Thanks to all for the input
Old 06-25-2010, 09:14 PM
GARB55
GARB55's Avatar
Glad you like em! Any Photo's??
Old 06-25-2010, 09:43 PM
Sandman93
Sandman93's Avatar
Originally Posted by pql-lbc
Holy 4x4!!! Drop it like it's hot!!!!
TOTALLY AGREE... LOL
OMG... THAT HAS TO BE DROPPED LIKE YESTERDAY...
Old 06-27-2010, 08:54 PM
z06sicz
z06sicz's Avatar
Default drop
looks like he did in post 24
I'll try to get some pics up
I dropped mine on the stock bolts 3/4" up front and 1" inch out back and no problems. I'm running c6zo6 speedline wheels factory sizes. Nitto invo's front and back. 275's up front and 325's out back
Old 06-28-2010, 11:59 AM
Sandman93
Sandman93's Avatar
Can we see it now that its dropped??
Old 04-07-2011, 01:11 PM
Nosferatu333
Nosferatu333's Avatar
Your the man! Just had them installed yesterday and they were clearly rubbing. But the car was on the lift. Im glad i found your post. I was about to mini tub my damn car. PIA! Ima go back to see how they fit once lowered to the ground.
Do you have any issues with rubbing on the road when bouncing?
Thanks again.
Old 04-08-2011, 08:27 PM
Red C6 Z06
Red C6 Z06's Avatar
St. Jude Donor '05 '09
I actually like the C5 Z06 wheels better than the C6 Z06 wheels, but they are smaller, aren't they?
Old 04-08-2011, 09:20 PM
firefighter813x
firefighter813x's Avatar
Those stick out too far for my taste. It's hard to tell by internet pictures.
Old 04-08-2011, 09:59 PM
  #33
GARB55
GARB55's Avatar
Old 07-07-2012, 12:27 AM
  #34
GARB55
GARB55's Avatar
Old 03-12-2015, 03:31 PM
  #35
1redz06
1redz06's Avatar
Any problems cracking fenders? I have some wheels made for a c6 z and just been paranoid to hit a bump with the car.
Old 09-02-2016, 11:46 AM
  #36
RomanNYC
RomanNYC's Avatar
how much did you pay to lower the car?
Old 09-02-2016, 05:35 PM
  #37
GARB55
GARB55's Avatar
I purchased LG's GT2 Coil Overs and installed them myself following Toque's guide.. see here
RomanNYC (09-02-2016)
Old 09-02-2016, 08:03 PM
  #38
RomanNYC
RomanNYC's Avatar
sweet.
Old 09-02-2016, 09:09 PM
  #39
Brett Smyl
1st Gear
Brett Smyl's Avatar
Has anyone swapped C7 Z06 rims and tires onto a aC5 Z06?
Quick Reply: [Z06] C6 Z06 wheels fit?
