[Z06] C6 Z06 wheels fit?
Old 04-29-2010, 08:26 PM
z06sicz
z06sicz's Avatar
Default C6 Z06 wheels fit?
Do factory C6 Z06 wheels fit on a c5 zo6?
Old 04-29-2010, 10:04 PM
z06gaston
z06gaston's Avatar
yes
Old 04-30-2010, 06:57 AM
dieseldave56
dieseldave56's Avatar
Default Yes
Yes, but some say the the rears may need a 1/4" spacer.
Old 04-30-2010, 08:24 PM
z06sicz
z06sicz's Avatar
Are the stock C6 Z wheels any lighter than the repo wheels?
And what is the cost difference?
I don't mind the spacer if I can get a 325 on the back.
Old 04-30-2010, 10:25 PM
LT1driver
LT1driver's Avatar
why the spacer...to clear the brake duct???
Old 05-01-2010, 01:10 AM
dieseldave56
Default wheel spacer
The wheel offsets for the rear C6 is different than say the c5 Z06. I don't know why some have used spacers to bring the wheel/tire out to the edge of the wheel well . The rear brake ducting interference is a tire diameterand /or side wall aspect issue usually, going from an 18" to 19" wheel .
Old 05-01-2010, 01:14 AM
ls2alex
ls2alex's Avatar
it'll look great...post pics when/if you do it
Old 05-01-2010, 06:58 PM
GARB55
GARB55's Avatar
C6 Z06 Wheels and Nitto Invo's installed, 275/35 18 up front and 325/30 19 out back. No spacers, had to remove rear brake ducts to fit the 12" wide rear wheels. This is very easy to do. Fronts stick out a less then a 1/2" and I'm not to crazy about this, will deal with it for now until I can afford a wide body kit or go with a different set up??. Rears look Sweet and only stick out about 1/4". The C6Z06 Wheels are heavier, I do not have exact weights but I have not noticed a difference yet. Next issue is she needs to be lowered and I need to figure out the best way to do this without damaging the tires? This is just after install and she dose not sit this tall now as she as settled..
Before
After with C6ZO6 set up
Old 05-01-2010, 08:02 PM
SSTG
SSTG's Avatar
Can't the fronts be taken in by adj/removing shims on Control arms?
Old 05-01-2010, 09:17 PM
03redzo6
03redzo6's Avatar
Old 05-01-2010, 09:23 PM
z06sicz
z06sicz's Avatar
anyone got pics of them on a yellow Z?????
Old 05-01-2010, 09:41 PM
LT1driver
LT1driver's Avatar
cool a corvette off-roader good thing it will settle..looks good.
Old 05-01-2010, 09:55 PM
pql-lbc
pql-lbc's Avatar
Before
Holy 4x4!!! Drop it like it's hot!!!!
Old 05-01-2010, 11:07 PM
GARB55
GARB55's Avatar
As stated!
Old 05-02-2010, 11:16 AM
z06sicz
z06sicz's Avatar
As stated!
Take it down with the stock bolts and check for rubs. I'm very interested in seeing how you make out, for I purchase the same rims. I'm lowered 3/4" and 1" front to back respectively.
Are those crome repos or OEM speedlines?
Old 05-02-2010, 08:58 PM
GARB55
GARB55's Avatar
OEM speedlines.
Old 05-03-2010, 12:17 AM
Milan
Milan's Avatar
IMO the C6Z wheel do not go with the lines of the C5, but also lowering would help quite a bit
To C6 Z06 wheels fit?
Old 05-07-2010, 10:02 AM
97C5inSD
Support Corvetteforum!
97C5inSD's Avatar
These are C6 wheels on ym C5 with L5 Fenders i needed a 5/8th spacer to get the wheels to clear and keep from rubbing since my car is lowered with coilovers.
Old 05-07-2010, 11:33 AM
z06sicz
z06sicz's Avatar
"These are C6 wheels on ym C5 with L5 Fenders i needed a 5/8th spacer to get the wheels to clear and keep from rubbing since my car is lowered with coilovers."
Did you install longer studs? And where did you get them?
Old 05-07-2010, 05:36 PM
97C5inSD
97C5inSD's Avatar
Randy at DRM provided me the spacers and yeah i have longer wheel studs i'm sorry i forgot about that.
Also the Rear wheels for them wondering are about 65lbs rims and tires. the tires where also Nitto invos
Quick Reply: [Z06] C6 Z06 wheels fit?
