[Z06] Water pump leak?
Water pump leak?
Hey guys just wondering if anyone can help me with isolating a coolant leak possibly coming from my water pump on my 2002 Z06 with 35,106 miles. I just started noticing the smell about 2 weeks ago followed by the spots on my garage floor. It does not leak while the engine is running from what I can tell, but after it has been sitting over night there are a few spots on the ground (about a teaspoon). I looked under the pump with a flashlight and mirror the hoses are all dry but I can see that it is wet behind the pump up along the engine block. I have not done a pressure check on it. The coolant level is still full.
Might it be that one or both gaskets are leaking?
What else should I look for? Thanks
It is directly under the water pump area. I can see the coolant between the water pump the the car is not running. I started it up and let it run until it got up to 200+ deg there was no leakage and the coolant leakage dried up (does not leak when running).
