[Z06] C6 ZR1 Brakes on a C5 - Serious Inquiry
Gentlemen,
I would like to know if any member of this forum has actually installed or knows first-hand of someone who has installed C6 ZR1 brakes on a C5?
I would like to here about the factual physical installation concerns.
I have just installed 19 x 10 inch front and 20 x 12 inch rear wheels, so I know I have clearance for the brakes.
Gentlemen,
I have just intalled 19 x 10 inch front and 20 x 12 inch rear wheels, so I know I have clearance for the brakes.
I dont know anyone that has them on a C5 but I do know they are a direct bolt on to a C5, with the proper wheels. Expect to pay in the $9-10k range if buying new.
In addition to the complete C6 ZR1 brakes at ~ $9,000, you need to install the C6 front knuckles at ~ $300.
The C5 knuckles deflect and bend under the braking torque of the ZR1 system.
The ZR1 brakes are good, but not "chassis" twisting good.
The single biggest advantage I see si the very low weight of the rotors.
I talked to the Corvette Chief Engineer at Carlisle last August and he told me about the knuckle deflecting. GM upgraded the knuckle on all C6s because of this issue.
Yes, it is a problem with big brake kits.
Oh well, I guess I never saw this "knuckle deflection" reported by any heavy duty brake users for the 10 years I have been tweaking and poking on my C5.
Supporting Vendor
St. Jude Donor '11,'13
What are you trying to acomplish with the ZR1 set up? You can go to a BBk with same results or better for 2k less.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Dave,
No, my Z06 is not a dedicated road racing car.
The brake mod will complete everything I want to do before I build a new motor.
I prefer the C5 Z06 and its roofline over any of the C6s. I don't plan on getting a new model, so I am modding my Z06 to keep it competitive.
