[Z06] Halltech emailTUNEŽ PowerTuning remote tuning now!
Supporting Vendor
St. Jude Donor '09
Halltech's exclusive emailTUNEŽ Tuning is World Class custom tuning done without leaving home. Remote tuning through Jim Hall's emailTUNEŽ is the easiest and best way to increase performance without going to the dyno. All tuning files have been street, dyno, and track tested for best results. emailTUNEŽ is customer based tuning using the SCT X3 Handheld Tuner, but is delivered by email, and is easily reversible in 6 minutes back to stock, for that Madonna (like a virgin) ECM. $489.00 covers the cost of the X3 Handheld and emailTUNEŽ PowerTune. For instance, if you have the Halltech Killer Bee II only, tuning is not required to run this intake, but we can bring more of the beast out with Power emailTUNEŽ.
How does it work? You purchase the SCT X3 Handheld Programmer, and use it to download your stock ECM file to the X3. You then transfer it to your laptop or desktop and email it to Halltech. We make the calibration tuning changes and email back the new file, which you upload to your ECM using the SCT X3 Handheld. That's it! You car is tuned!
We emailTUNEŽ cam profiles to companies like Geiger Performance in Germany, for their Katech cam packages, to stock Z06s. Jim Hall personally calibrates each emailTUNEŽ. emailTUNEŽ is a registered trademark of Halltech Systems, LLC
Features:
Increases Horsepower & Torque! Halltech's emailTUNEŽ tunes your Corvette by email!
Increases your vehicles Horsepower, Torque, Throttle Response and even Fuel Mileage
Huge Backlit LCD Display
Huge backlit LCD display for easy viewing, day or night.
Reads/Clears DTC Trouble Codes
Reads and clears diagnostic trouble codes quickly & easily, saving on expensive diagnostic fees.
Backs Up Factory Tune
Stores your vehicles factory tune file for easy restoration back to the stock program.
Dual Analog Inputs
Monitor EGT temps, air-fuel ratio and other popular sensor data.
Installs Quickly & Easily
Installs in minutes via your vehicle's ODB-II port
Stores 3 Custom emailTUNEŽ (Cam tuning additional)
Stores up to 3 custom tune files created by Jim Hall. Jim has over 8 years experience tuning Corvettes.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
User Adjustable Vehicle Parameters
Adjust for common performance bolt-ons such as Cold Air Kits, Exhaust Systems & Gears
Free Data Logging Software
SCT's Livelink Data Logging software included
Most Popular Vehicles Supported
Most popular General Motors vehicles supported.
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
