C5 & C6 Powder Coated Rebuilt Calipers-FREE SHIPPING!
#61
Supporting Vendor
St. Jude Donor '11
Spring is just around the corner! Lots of C5 & C6 Calipers & Brackets in stock! If you order what we have in stock there is no waiting! I also have some un coated units in stock and can make custom colors!
To place your order please go to www.TPSMotorsports.com
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
#62
Supporting Vendor
St. Jude Donor '11
Are you looking to get rid of those ugly stock grey calipers? Get a set of our Powder coated calipers! Below are samples of colors we've done... some colors are in stock and ready to ship.. no waiting
#63
Are these prices still valid?
thanks,
Ray
thanks,
Ray
C5 & C6 Powder Coated Rebuilt Calipers-from $329.99 FREE SHIPPING!
CALIPERS ARE 100% REBUILT WITH NEW BOOTS AND SEALS!
-Brakes are a safety issue and we take YOUR safety very seriously. We DO NOT USE ANY OLD/ USED BOOTS or SEAL.
Our powder coating process has 2 coats of powder coating applied to each caliper and bracket which hides alot of the casting imperfections on the caliper. We can also powder coat your own calipers. If you are interested in purchasing a set of TPS Powder Coated Calipers OR having your calipers powder coated please contact us. A $400 core charge will be applied when order is placed and your old calipers must be sent back to us to receive your core charge back. Cores must be in good condition without damage.
Caliper brackets are powder coated so the pads can "float" freely in the bracket
-When caliper brackets are painted or powdercoated you MUST make sure the area where the pads sit are free of excessive powder coating. If there is excessive powder coat it will cause your brakes to bind.
Please take a look at our caliper bracket on the right as it is free of excess powder coating in areas where the pads sits... allowing it to "Freely Float" and NOT BIND.
Why not get a complete brake kit from TPS?
Whether your looking for just......
Rotors from $219.99
*Our rotors are made by Centric, the makes of Stoptech Brakes, and the cooling vanes are directional
http://forums.corvetteforum.com/c5-p...free-ship.html
TPS Stage 2 Brake Upgrade kits which includes Stoptech or Hawk Brake Pads, Stainless Steel Brake lines, rotors, and Motul Brake Fluid for only $499 shipped to your door!
Rotors from $219.99
#65
Did they not ship yet?
Please let me know!
Thanks!!
#66
Supporting Vendor
St. Jude Donor '11
Depending on the color your ordered and if it was Z51 or non-Z51 there may be a wait for several weeks. We have to wait for cores to be returned to us to process the next batch of orders... I do have a batch of calipers that are done coming in today so depending on where your order is in the que and color requested.
#67
Supporting Vendor
St. Jude Donor '11
Good amount of calipers in stock and ready to ship....
C5 Red (2 Sets)
C5 Yellow (1 Set)
C5 & C6 Candy Blue (1 Set each)
C6 Candy Red (1 Set)
C6 Gold (1 Set)
C5 & C6 Black (1 Set each)
C5 Silver (1 Set)
C6 (2 sets no done so can make ANY Color You want)
C5 Red (2 Sets)
C5 Yellow (1 Set)
C6 Gold (1 Set)
C5 Silver (1 Set)
#68
Mike is a great guy to deal with!
I bought a set of C6's in RED. Arrived well packaged, great price, great quality, great result!
The brackets really look nice along with the calipers!
Thanks MIKE!
Hope to do business with you again!!
Ray
Thanks MIKE!
Ray
#70
Supporting Vendor
St. Jude Donor '11
Check out some of the TPS Powder Coated Calipers Recently installed on customer's car's recently
Candy Red TPS C6 Powdercoated calipers
These were silver and we powder coated them red,
GOLD TPS Motorsports Calipers
#71
Supporting Vendor
St. Jude Donor '11
Looking for some Powder coated calipers to make your Vette stand out? Here's what we have available to ship immediately. Other and custom colors available for a short wait. Upgraded rotors and stainless steel brake lines available at a great price also.
C5-Red (2 Sets)
C5-Silver/ Grey (1 Set)
C5-Candy Blue (1 Set)
C6 (Base)-Red (3 Sets)
C6 (Base)-Black (1 Set)
C6 (Z51)-Candy Orange (1 set)
C5-Red (2 Sets)
#72
Supporting Vendor
St. Jude Donor '11
Git rid of those ugly stock calipers and get a set of TPS Motorsports Power Coated & Rebuilt Calipers!
-Lots of colors in stock and ready to ship immediately!
#74
Supporting Vendor
St. Jude Donor '11
End of 2015 Special for all Powder Coated Caliper Purchase!
Buy any set of powder coated calipers and we will give you a set of Speed Bleeders for them FREE OF CHARGE!
The old manual way of bleeding your brakes
Bleeding brakes used to be a difficult thing to do in the past. It generally required two people to bleed brakes. You had to have one person pump the brake pedal while you had the mechanic open and close the bleeder screw. You had to coordinate the openings and closings with the pumper. If you didn't coordinate the timing correctly you could end up with more air in the system than when you started.
The new and improved way
Introducing SPEED BLEEDER?, the patented bleeder screw with the built-in check valve. It is truly a one-person bleeder screw. Once installed, it becomes a permanent part of the brake system. When it is time to bleed your brakes, you loosen the Speed Bleeder 1/4 turn and pump your brake pedal. When the pedal is depressed the pressure generated opens the check valve letting air and brake fluid out of the end of the Speed Bleeder. When you release the pedal and it returns to the up position, the check valve closes and prevents any air from reentering the system through the Speed Bleeder. When bubble free fluid is evident you close the Speed Bleeder. In the closed position it works just like your stock bleeder screw and prevents any brake fluid from leaking out. It generally takes about 5 pumps to purge each caliper or wheel cylinder. That is all there is to bleeding your brakes. If at a later date you need to bleed your brakes, the patented thread sealing system makes it easy to open the bleeder screw to perform the bleeding operation. It is made of quality materials and it is economical.
#75
Supporting Vendor
St. Jude Donor '11
Get a set of Powder Coated Calipers from only $299 now!
Special December Christmas Pricing!
Bump for our best sale of the year! Everything is on sale!
Click here to place your orders
http://www.tpsmotorsports.com/black-...-corvette.html
0% Financing Available for up to 1 Year on ALL PURCHASES!
#76
Supporting Vendor
St. Jude Donor '11
Swap out those ugly stock calipers while your Vette is put away for winter with our Powder Coated & Rebuilt Calipers.. from only $339 shipped to your door.
#77
Supporting Vendor
St. Jude Donor '11
#78
Supporting Vendor
St. Jude Donor '11
SPRING IS HERE! IT's RACING & SHOW SEASON!
Get rid of the the UGLY stock calipers with a set of our Powder Coated and rebuilt calipers! Pick a color we stock OR any color that's available!
#79
Supporting Vendor
St. Jude Donor '11
Lot's of calipers in stock and ready to ship! No waiting for many colors for C5, C6, and C6 Z51! If we have it in stock we'll ship it out to you within 48 hours of placing your order!
#80
Supporting Vendor
St. Jude Donor '11
