[Z06] Here is a useful product for the up coming hot weather!
Supporting Vendor
There's a lot of benefits to keeping your Vette running cool!
Here is SacCityCorvette’s latest version of the Cool It v2 and v3 Remote High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6.
Now you can control your C5 Corvette's radiator high speed cooling fan with the simple push of a button on your wireless FOB, allowing you to control your radiator coolant temps. No need to pay for a expensive tune to change your fans on/off temperatures or running you’re A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
The Cool It v2 and v3 now run on their own circuit and will not interfere with the normal computer controlled operation of your cooling fans.
Installing the Cool It v2 and v3 is a very simple five minute plug and play installation. (See our installation video) After you install the Cool It v2 or v3, you will be able to turn on the right side cooling fan on in high speed mode using a wireless FOB making it perfect for when you are at the track and you want to cool down between runs, in traffic and idling in parades. It will even help keep your Automatic Transmission running cooler too!
That’s why you should install a Cool It!
Only $99.95!
Watch our installation video and see how easy it is to install the Cool It!
http://www.saccitycorvette.com/Cool-...sll-video.html
Here is a link with more information!
http://www.saccitycorvette.com/COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
