[Z06] ***Build Date/VIN Analysis of LS6 Valve Spring Failures***
#381
Just to make sure I am interpreting the VINs right. I am looking at an '04 but has the last 5 of 20724. Did they start over on the last 4 digits for the '04 year because just looking at your graph and based on my VIN number, it looks like I should be in the danger zone with the '02 models.
#382
#383
St. Jude Donor '08
As my "VIN" falls in the middle of the list for failure I just replaced the valve springs in my 02 Z06. Used the "blue springs" from Gene Culley. As posted in this thread, the stock springs were yellow. The only odd thing was there were only 15 springs that were yellow and one spring that was what I would call gray. Don't know if this came from the factory or someone replaced one spring. When I purchased the car it had a little over 6500 miles. I'm leaning towards this being done when the car was built. Glad nothing happened while I had the car at VIR.
Gene
Gene
#384
Well you can add me to the list as of 4/19/15. 2003 Z06, springs must have failed at shutdown or startup because when I parked the car on a quick errand it was fine and when I tried to start it back up it wouldn't fire or run correctly.
2003 Z06 w/ 72,094 miles
VIN: **********110945
#386
That sucks. Hopefully it didn't mess anything up. I just looked through mine and pulled a valve cover off. Mine is a late 03 and I have silver valve springs. are yours yellow? What are you gonna replace them with? Debating if I am gonna do mine
#387
Mine are raw finish (just texted my seller, still in town for now, moving to Roatan Honduras soon; bugger), he never replaced the springs. I'm an 04Z; built 09/03 with SN 06313. Anybody go to the trouble of digging into the few 04 models that had failures, and see if they had a common build date range?
#388
I am in low category but still a 2003 Z I will be replacing mine for insurance. I am not taking the chance of buying oem ones. Would rather have aftermarket ones. I called Hinson to see what they have to say. I was going to do pac 1218 however when I called them they told me they would recommend the lunati springs http://www.hinsonsupercars.com/p-1308-lunati-ls-dual-valve-spring-kit-660.aspx
I am running factory cam. My mods are ECS blower at 8psi and full exhaust. I won't be doing a cam in this motor so those seem way to aggressive. What's everyone's thoughts about what Hinson said.
#389
Ive got my head at the machine shop, he is sourcing the valves for me. I will be replacing all the springs with with oem parts.
I heard the intake valves are discontinued, not so good for me.
#390
Joined the club Saturday.
On the way to work car started running really rough. Number 7 cylinder valve spring had broken. They were yellow. June 02 build. 72k miles.
#391
Numbers, graphs, and lists on the first page have all been updated with the latest info.
162 broken springs and counting...
#392
I have a 2002 Z06, built in November of 2001, last 5 digits of VIN are 12804. The car has 10k miles on it. Should I be concerned and look to replace the springs, or am I out of the "danger zone"?
#393
My build date is 09/01 and I have 60k on my C5 Z06. I haven't changed mine as of yet but I still plan on it when I get a chance.
#394
You feel you need to crack open your engine to replace the valve springs because a total of 6 people (from our build time frame) have reported failure in 13 years?
#395
Daddie O I'm not going to stress over it per say, but I will change them whenever I do a cam swap in which won't be probably until another year or so.
#398
Had mine replaced this week with PAC 1218... Car has almost 100k km on it... Waiting for some pics from my mechanic how the originals looked...
The chance of one breaking is low but this gives me a little piece of mind...
Put in new spark plugs as well... 41-962 AC Delco's... Had to remove them anyway to put air in the cilinder...
#400
03 C5Z Cracked valve spring - Build 05692
Car was running like all hell, Vibrating.
Just found driver side valve spring cracked.
Didn't drop the valve, hopeful it's straight
DD 03' Z06 54k Miles Build 05692
New Replacement from GM are stock # 12625033 - They're Blue
Replacing all 16 springs, 8 plugs(NGK TR-55) $30, 8 wires(MsD)$70
Cost around $250 in part
