[Z06] Where to put the money? catch can or stainless brake lines?
where do you guys think the money would be better spent? Catch can or stainless steel brake lines. The car has good rotors on it with factory pads.
thanks for the response, why would you choose the can? I'm undecided so could you explain why? I would like to hear different opinions.
Justin
Justin
IMO a catch can is a must have. It keeps oil out of the intake system. These motors are notorious for passing oil and gunking things up. You will understand when you go to drain it. It's an item I would not hesitate to buy used. Brake lines are good if you autox your car but you will want the catch can for autox also.
I just ordered one myself, will likely install it tomorrow. SS lines are on my list too.
Catch can. I'm amazed at how much oil accumilates in there and I'm primarliy just an aggressive street daily driver with rare occurences of high performance driving. Oil that would've been in the intake tract. Stock brake lines however are working just fine.
Personally, I wouldnt do either but if I had to choose, catch can. As long as the install goes right, there is a benefit. And it does dress up the engine compartment a bit.
I chose the catch can. The local race car shop only had a breathable one so I temporally installed it in case I want the non breathable one. I have the pcv valve in place which at this point may be useless with the breather. So this mod can't hurt the engine in any way?
