[Z06] MGW shifter installed, wow!
Old 10-31-2012, 06:08 PM
janky
janky's Avatar
Default MGW shifter installed, wow!
Changed my transmission fluid to Royal Purple Syncromax, did the anti-venom mod, installed a new C6 shifter box and threw the MGW on top of it today. Wow what a dramatic improvement in shift feel and quality, I'm really going to enjoy banging through the gears now!
Also special thanks to Toque for his helpful website detailing the tranny fluid change and detent plug mod, made things extremely simple!
Here's a crappy pic from my work parking lot, I even love the new shift **** (MGW as well).
Old 10-31-2012, 07:15 PM
ZEE-OH-6
ZEE-OH-6's Avatar
Curious, do you have to install a C6 shifter box to install the MGW in a 2004 Z06 ?
Old 10-31-2012, 07:17 PM
janky
janky's Avatar
No, but MGW doesn't recommend using a Z06 shifter box with their product. The regular boxes have rubber isolators, the Z06 boxes have metal bushings and will transmit vibration.
Old 11-01-2012, 12:13 AM
skyavonee
skyavonee's Avatar
I run a MGW with the stock shifter box without any problems. I'm pretty sure there are many others with the same setup, too.
Old 11-01-2012, 12:27 AM
AtxjusticeZ06
AtxjusticeZ06's Avatar
Does "anti-venom" make a big difference? Installed my MGW yesterday and although I like how precise it feels..shifter is very notchy and first gear takes some work. Wondering if putting a washer on the detent bolt would help take some of the required effort out of it.
Old 11-01-2012, 12:54 AM
Gmzo6
Gmzo6's Avatar
Could explain the anti-venom and mgw mod?
Old 11-01-2012, 12:56 AM
skyavonee
skyavonee's Avatar
Definitely. I first tried a 3/16" washer but it made the shifter feel way too loose. I backed it down to 1/8" and it feels just right to me. Still clicks into gear, but doesn't require a lot of shoulder effort.
Old 11-01-2012, 12:58 AM
skyavonee
skyavonee's Avatar
MGW is a popular brand of aftermarket shifter. The anti-venom mod involves putting a spacer on the transmission detent bolt to loosen up the stiffness of aftermarket short shifters. Do a forum search for "anti venom" or "detent bolt" and you'll find directions and a how-to diagram.
Old 11-01-2012, 12:59 AM
Gmzo6
Gmzo6's Avatar
Just did thanks! Sometimes I get ahead of myself lol
Old 11-01-2012, 01:13 AM
janky
janky's Avatar
I can't speak for what the MGW feels like without the washer, but it doesn't feel notchy at all with it installed. Of course that's just my opinion.
Old 11-01-2012, 08:22 AM
Maxx_Z06
Maxx_Z06's Avatar
C5 COTM Coordinator
I can vouch for the Anti- Venom Mod. For sure a must if installing any short throw shifter to reduce the "notch" feeling.
Old 11-01-2012, 08:23 AM
Maxx_Z06
Maxx_Z06's Avatar
C5 COTM Coordinator
I can vouch for the Anti Venom-Mod. For sure a must if you're considering installing an aftermarket short throw shifter. Really reduces the "notchy" feeling.
Old 11-01-2012, 10:04 AM
jpalamar
jpalamar's Avatar
I'm running the MGW shifter as well. Stock shifter box. Its def notchy and you can feel/hear vibrations. Its too agressive for the street at first but I got used to it and now I love it.
Old 11-01-2012, 10:10 AM
PEETYZ
PEETYZ's Avatar
MGW shifter ordered for my 01 Z. It currently has a C6 shifter in it which IMO feels way too sloopy.
To my knowledge it has the stock shifter box but I may be wrong.
Old 11-01-2012, 01:15 PM
zeevette
zeevette's Avatar
When the C6 shifter was installed, it came with a new box attached, so you should have a C6 box on yours. I do, and I could tell no visual difference between my original C5Z box, and the C6Z one.
Old 11-01-2012, 02:14 PM
PEETYZ
PEETYZ's Avatar
Thanks!
Old 11-01-2012, 02:15 PM
janky
janky's Avatar
my understanding is that a C5Z or C6Z specific shifter box has solid metal bushing mounts whereas standard C5 and C6 boxes have rubber isolators. They discontinued manufacturing of the Z06 style boxes some time back so there's only one part# now, it's easy enough to look at the mounting points on the right to see if they have rubber or metal bushings.
To MGW shifter installed, wow!
Old 11-01-2012, 04:30 PM
lsxvette
lsxvette's Avatar
ordering mine now
Old 11-01-2012, 05:00 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Glad to hear it worked out so well for you !
Toque
Old 11-01-2012, 08:31 PM
MY03C5Z
MY03C5Z's Avatar
Installed the mgw in mine last winter, I love it but didn't know about switching to the c6 base. I may have to add that item.
Quick Reply: [Z06] MGW shifter installed, wow!
