[Z06] Forgestar F14 Info & Pic Thread
#541
My 18/19 gloss black f14s have finally arrived after a 3 month wait! Cant wait to get them on, doing 01-04 tpms conversion and installing c6z brakes before they go on. Will post pics when they are mounted!
#542
Here are a few more pictures.
Could it be that your car is adjusted for wider wheels in the first place since it is a Z06. My car is a standard coupe 1997 model with 245 in the front and 275 in the back.
Are there any difference in the wheel barrel width on a coupe and a Z06?
Let the suspension settle, and if they still stick out that bad, lower the car to tuck them. In your pics, it appears your car is sitting higher than stock, so it either hasn't settled yet or was never lowered to proper height after it was shipped. These cars bring the tires in as the suspension is lowered.
#543
I'm currently running tsw Nurburgring in 18/19 gunmetal finish, they are in awesome condition with around 5000 miles on them and the tires, what started this whole new wheel thing is that at just under 650 rwhp traction has been the issue, so if I was going to get new tires I figured I would get wheels as well, plus the Tsw offset has never looked right to me on the rear.
The black graphite looks like his has enough if a silver Hew to it that it will look good with pewter, I Hope
#545
Beautiful car. Glad to see it fits well in the back. Wonder what would happen if you put it upfront. I don't plan to run wider than 285 but I'm not sure how much the 305 sticks out over a 285
#549
Smexy RustinPeace. Your car looks fantastic for any mileage. I managed to get mine mounted today.
F14s:
18x9.5 ET50
19x11 ET55
Nitto Invo:
305/30/19
265/35/18
About 1cm poke. I kinda like it that way.. roughly the same amount of poke as 295 MPSS. Also the black paint is coming off a couple of the lugs but it's no biggie, can repaint pretty easily.
Thanks N4SM, zdeckich, rjwz28, MotoJB and everyone else who helped out.
F14s:
18x9.5 ET50
19x11 ET55
Nitto Invo:
305/30/19
265/35/18
#553
Does anyone have a picture of the fronts sticking out? Got my F14 mounted up and the fronts stick out an inch... I think they sent me the wrong offset. 18x9.5 wheel offset on invoice shows 49mm. I am measuring the offset and looks to be 44mm. Rears are 53mm and fit perfect. Its a 1999 C5.
I see others are using the 49/50mm offset with a 18x9.5 wheel - why doesn't forgestar use the stock Z06 offset of 54mm??
#558
2018 C5 of Year Winner
