[Z06] Forgestar F14 Info & Pic Thread
#701
Is your rear fascia plasti dipped or painted? It looks good, and I am thinking about doing that to my MY Z.
Shakey
Shakey
#704
Received 1,679 Likes
Are you still here Zach.... Move on over to the CTSV forums... You Benedict Arnold you!
VibeMotorsports (09-14-2017)
The following 4 users liked this post by tommypenguin:
IMXCITD (12-29-2016),
tdf01cycling (12-20-2017),
VibeMotorsports (09-14-2017),
wiz_of_wuz (08-22-2021)
#707
I just installed my 19 X 11 with a 55mm back space. The flush mount caps seem to push out 1/16 of a inch. The rubber o ring is in. Will they fall off or not. They seem tight.
As far as poke. 305/30/19. Maybe a 1/4". Nothing to worry about
#709
http://www.americanmuscle.com/forges...centercap.html
#710
Supporting Vendor
Our customers lowered Mustang sitting on a set of gorgeous Forgestar F14’s.
Attachment 48361460
Attachment 48361461
Attachment 48361460
Attachment 48361461
#712
Supporting Vendor
Exciting news to share! Forgestar is running another one of their rare sales!
Until October 14th, 2016 Forgestar is offering a $200 discount on all NEW orders!
To claim this deal, please go to http://www.forgestar.com/ and submit your email, then get in touch with me for the order!
I already checked, and unfortunately this will not apply to any old or existing orders in produciton, sorry about that. I just found out about this deal today.
Contact Jason@GetYourWheels.com to take advantage of this deal ASAP!
#715
Supporting Vendor
All current Forgestar wheels are built to 72.56 and are hub ringed down to 70.3 for the Corvettes. So its recommended to use the hub rings.
But I do know that some of my Vette customers prefer to use no hub rings and havent had any issues. Just make sure to torque down the lugs in the star pattern so they'll fit lugcentic.
If you get any vibrations then the hub rings would probably be recommended
Hope that helps!
Hope that helps!
#716
Hope that helps!
Hope that helps!
#717
Supporting Vendor
Some updated shots of Erik's C5 we set up with with Satin Bronze F14s!
Attachment 48359122
Attachment 48360691
The ride is coming along nicely and looks even complete with the front lip now!
Attachment 48360692
Attachment 48359122
Attachment 48360691
Attachment 48360692
#718
here are some updated pics, after I lowered the rear a little more. 19x11 18x9.5 305/30/19 265/35/18 lowered on stock bolts in the front, with the bushings cut off, and zip bolts in the rear.
The following 2 users liked this post by ErikwithAK01:
a_ahmed (02-28-2017),
#719
Supporting Vendor
Our customer recently installed a set of Forgestar CF10's for his ZR1. The finish he decided to go with, gives his car a stealth black on black look. Thanks for the support.
So I decided to ditch the GM Cup wheels not that I didn't like them
(believe me I do like the Cups) I want to go with a 19" setup on all four corners.
I went with the Forgestar CF10 in gloss black 19X10 +30 up front and 19X12 +50 in the rear. I am running NITTO NT05 275/30/19 and NT05R 345/30/19.
Car rides excellent and hooks great! The offset in the rear gives it a much better look than OEM wheels. I could not be happier with the service I received form GetYourwheels.com my sales rep Jason was awesome the wheels came mounted and balanced, filled with nitrogen with black wheel weights and black TPM stems installed on the new sensors.
If you looking form some wheels give these guys a look they are forum vendors and my reps contact info is below. You wont be disappointed.
Jason Tung
EMAIL: Jason@GetYourWheels.com
WEB: www.GetYourWheels.com
PHONE: 562.219.2525
FAX: 562.268.1652
Jason Tung
PHONE: 562.219.2525
FAX: 562.268.1652
#720
Supporting Vendor
Here are some shots from our good customer whose been in the process of building up his C6
Set 1:
C6 Stock fenders with Forgestar F14s in Black Graphite 19x9.5/20x11 in semi concave
Attachment 48360202
Attachment 48360203
Set 2:
He widebodied the C6 with Grandsport front fenders and Z06 rears!
We set him up with deep concave Forgestar CF5s in 18x10/19x12 with a custom upgraded Brushed Gunmetal Finish!
Attachment 48359066
Attachment 48360204
Attachment 48359065
Both sets came out looking great!
Set 1:
Attachment 48360202
Attachment 48360203
Set 2:
Attachment 48359066
Attachment 48360204
Attachment 48359065
