Check our version of the Big 3!
Supporting Vendor
Hi Everyone!
We have put together a Big 3 kit for you that is easy to install!
With all of the high-tech electronics that have been incorporated into your C5 Corvette, not to mention additional after market electronics and stereo systems, it can take a toll on the factory charging systems ability to keep up. Especially if, over time, connections have become corroded.
Installing a BIG 3 upgrade can be very beneficial as many on the Corvette forum will tell you. SacCityCorvette has developed a BIG 3 installation kit for the C5 Corvette. It is made from all high quality materials and designed so it will not look like an aftermarket universal kit. For safety it has a 100 amp heavy duty fuse, uses automotive grade 4 gauge wire, (not the type most car stereo shops use), the positive wire has a mesh sleeve over it for additional protection, all connections are hydraulically crimped and come with all the hardware needed to do the install. The installation takes about thirty minutes with simple hand tools. If you have doubt that this BIG 3 kit will make any difference in your charging system, please check out our test video below and see how the voltage increases when we connect it! Update: If you have an issue with your lights dimming when you turn on other power accessories, several people have reported that our Big 3 has fixed that.
Here is the link with all the info. http://www.saccitycorvette.com/Big-3.html
Side terminal $119.95 Top Post $139.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Hi blueku,
I just tested the one on this post by clicking on it and it worked for me.
Try going here and clicking on the videos.
Thank you!
Christian
Thank you!
Christian
Supporting Vendor
Top battery terminal mount Big 3 now avaiable!
Check it out! http://www.saccitycorvette.com/Big-3.html
Supporting Vendor
If you have a Top Post Battery we have you covered!
Supporting Vendor
Supporting Vendor
Our Vette just seemed like it ran better with the Big 3 installed.
Could be in our heads or could be the that the extra voltage
really helped. Just saying!
Supporting Vendor
This is a great add on for you that have after market stereo systems
Supporting Vendor
We also offer more products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will get back to you with quotes and do our best to save you some $$$$!
Thanks,
Matthew
Sales@saccitycorvette.com
Thanks,
Matthew
Supporting Vendor
These Big 3 upgrades do make a difference. Just ask the owners that put them on their Vettes.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Damn you love answering your own posts
