Protect your Z! Check it out!
Supporting Vendor
Hi Everyone!
C5/C6/ C7 Corvette owners know that the front skid plates are vulnerable to getting bumped and scraped. Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6 / C7 Corvette. Made of a High Impact Superior Performance Plastic, the C5/C6/ C7 Fangs are extremely impact resistant and 6 times more abrasion resistant than steel and Installation only takes a few minutes. Being only 1/8" thick you will not even notice any clearance loss. There is NO drilling or modification required! C5 Fangs are a simple 10 minute bolt on using your factory bolts.C6, you simply glue them on or if you prefer, they can be screwed if you order the screw on kit. It comes with drill bit and tapping screws. Once the Fangs are installed you will have the best protection available. $49.99 is a very small price to pay for such good protection of such an expensive part of your Vette!
(Note: we still have the screw on C6 Fangs for those who prefer them. Check our website)
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4) They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)There is no drilling or modification needed to install them
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest.
9)They look like something that came on your Vette from the factory.
Here is a video of the Fangs getting used!
http://www.saccitycorvette.com/See-t...n-Action-.html
Here is info for the C5 Fangs
http://www.saccitycorvette.com/Fangs.html
Info for the C6 Fangs (Note: we still have the Screw on C6 Fangs for those who prefer them. Check our website)
http://www.saccitycorvette.com/C6-Fangs.html
Info for the C7 Fangs $66.95
http://www.saccitycorvette.com/C7Fangs.html
C6 Glue Fangs
C6 Screw On Fangs
Fangs will help prevent this from happening.
No gluing for the C5 Fangs. They bolt on with factory bolts.
Some of the Benefits
1) They are only 1/8” thick so there is no noticeable ground clearance loss. That’s very important since there is not much clearance there to begin with!2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
C6 Glue Fangs
C6 Screw On Fangs
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Fangs are a worth while investment for your C5 or C6 Corvette!
Supporting Vendor
If you feel that you need Fat Daddy's with the Fangs you can mount the Fat Daddy wheels but you will have to drill the Fangs for the FD bolts. Shouldn't be a problem.
Supporting Vendor
Supporting Vendor
We offer a lot more of the top name brand products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will be glad to get back to you with quotes and do our best to save you $$$.
Thanks,
Matthew
Thanks,
Matthew
Do the C6 screw on fangs work on the C5 - is the fit exactly the same on the skid bar? I'm assuming so, but just want to make sure. Thanks!
Supporting Vendor
Hi ZeeOSix,
No, C5 and C6 are completely different. You can see the differences in the pictures on our website.
C5 Fangs
C6 Fangs
Thanks,
Christian
Christian - thanks for clarifying that. Could you guys set me up with screw on fangs for a C5? Guess all you'd have to do is put the holes with a countersink in the fangs and supply the hardware kit. Not sure if you guys make these in-house, or have them made by a supplier to you. I just like the screw on setup better.
Supporting Vendor
No drilling or modification on the C5. Just bolt them on with the existing bolts that hold the air dam on. Very simple.
Here are the instructions.
http://www.saccitycorvette.com/C5_Bl...structions.pdf
Here is where you can order.
If you have anymore questions let me know!
Christian
Guess I'm confused. So you guys have two different styles for the C5? One you glue on and one that bolts on using existing bolts? Is the C5 bolt on pair cheaper because it doesn't come with all the glue, sandpaper, wire ties, etc?
Supporting Vendor
And 2 styles for the C6. Glue on and screw on for the C6
C5 and C6 are the same price.
Christian
Supporting Vendor
Hi LT! driver,
Fangs protect the protector! Hahaha!!
Christian
Christian
Supporting Vendor
The C6 lower radiator support is aluminum so its especially fragile.
Supporting Vendor
Did you know: The name "Corvette" was borrowed from a line of small, fast navy ships used in World War II.
