Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
Planning a cam swap or engine rebuild? AlignIt Tools can help with the rear main, timing cover and seal install. And get it done right the first time with less chance of leaks!
Supporting Vendor
Supporting Vendor
Here is a simple but very effective tool to help you make easy work of aligning your LS1-2-3-6-7-9 Timing Cover, Rear Main Cover. They even install the seals.
