Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
AlignIt Tools are to designed to align the Timing Cover & Rear Main Cover and install the Seals on all LS base engines.
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 Timing and Rear Main cover and seals. Works with all LS based engines!
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/AlignItTools.html
Here is a video that shows how simple it is to use. Tools used in videos are prototypes. The tools we sell are much nicer!
Installation with Oil Pan off.
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
The AlignIt, aligns the timing cover with the crank in seconds and then makes installing the seal easy!
Supporting Vendor
Thanks z99ls1!
When your ready to do another build we will
have the AlignIt tool waiting for you.
Christian
Christian
Supporting Vendor
Hey everybody,
Does anyone that has used the tools already, have any feed back for us? Good or bad. Keep it professional.
Thanks,
Matt
Thanks,
Matt
Supporting Vendor
We also offer more products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will get back to you with quotes and do our best to save you some $$$$!
Thanks,
Matthew
Sales@saccitycorvette.com
Thanks,
Matthew
Im getting ready to install a cam, timing chain, and oil pump on a friends Ls1
how much for all the tools to do it all event the rear cover shipped to 45807 and is there a Forum Discount?
Supporting Vendor
1999firehawkls1
Here is a link to the web site for all the tools. There are package deals
http://www.saccitycorvette.com/Timin...nmenttool.html
Supporting Vendor
azmotorhead
Thanks for your order. Please let us know how they work for you
Supporting Vendor
These tools ensure alignment accuracy and time savings!
How about a special price on the front cover and oil pump tools?? The newer rear covers from GM almost align themselves. But, I would like the other two listed above. Thanks for a great product
Supporting Vendor
Supporting Vendor
