[Z06] Extracting more performance out of your Z06
Here's a trick of the trade many of you may not know, relocating your battery. You do this, you'll have close to 50/50 weight distribution, greater for high performance driving.
So how much does all this extra stuff weigh? And is it safe to have a wet cell battery inside the trunk which is open to the cabin?
Considering the battery is next to the firewall and not on the nose, it does not affect weight balance as much as say a pre-2005 Mustang would. I am thinking if someone is this concerned with weight and balance then adding additional weight with an amplifier/stereo system is defeating the purpose. To me I don't think with the stock battery location the relo is really worth the gains over just installing a smaller battery. However to each his own.
Of course, the benefits of fine tuning the weight distribution assumes the driver skills are so good, so refined, that overall performance is being held back by the small difference in weight distribution caused by the battery position.......Really????? You folks really believe your skills are that good????
I know mine aren't. If they were I would be making a living driving.
No disrespect intended, but, really...
Danny
Danny
Tried relocating the battery to the trunk on my old 97z, it was nothing but problems. Added multiple grounds, used heavy gauge wiring (1/0 ga) and I could never get it to start right, always a weak start or not at all. Finally gave up on it and went back to stock. I would never mess with the battery location on the c5z. If anything I would just use a lighter battery. Just my $.02.
Danny
Danny
I too went with the Odyssey battery. I doubt many people are going to smaller batteries who put a bunch of stereo equipment in their car.
Danny
Danny
- I'm implementing an Optima Yellow Top D35, about five pounds less with same or greater CCA's, plus far greater reserve capacity, for listening to music in a parking lot, for example
- Typically sealed batteries are going to be fine, you don't have to worry about corrosion, safety, or reliability
- Additional equipment is minimalistic, you don't really have to implement the LPE one I have displayed, get another box from SummitRacing.com including wiring kit, another six pounds at the most
- After relocation amplifier installation is not very complicated, your distribution block can now be just a terminal block right off your battery
- Remember, you're subtracting 40 pounds off the front of the car AND adding 35 pounds to the rear of the car, +75 pounds F/R weight distribution
Thats why every BMW that I know of come with the battery in the trunk. I may do it someday to my Z06 as well, besides the weight distribution benefit, the battery now lives in a cooler environment and lasts longer. Win/Win...
You can get crazy will all sorts of amps, capacitors, wires, connectors, distribution blocks, etc, however better car control is the goal. This is for implementation of weight distribution, which is the difference. Stronger weight transfer implements greater balance, faster corrections, more accurate driving.
Cool write-up but I agree with the above. IMO, this is for full blown race cars and even then it's strongly debatable if one's skills are that good where you would notice the relocation. I've never heard of someone winning a race because one guy relocated his battery and the other guy didn't.
I don't see any odd or negative posts above...maybe slightly a bit of sarcasm from one or two. I stick to my guns that for a daily driver that occasionally goes to the track, this mod wouldn't show much of a lap time gain, if any, like it would on cars with batteries out on the nose. But if I were to make my Z a dedicated track car then I would probably be considering this as well. Like I first said...to each his own.
All the time, I hit apexes back and forth to Circle K repetitively.
EDIT: Didn't know you were talking to the rookie mister yellow corvette, nonetheless, I often hit canyons as well, handles fantastic.
