[Z06] 2003 C5 ZO6 - Ultimate Street Car build
(more pics and event updates on page 4)
The car has been through quite a bit of changes, thought CR was as good of a place as any to share it.
The car will transition back to racing with turns. I had fun at the drag strip thing, but I just enjoy road racing more. I am building the car to do the Pro-Touring style thing, for street car events, primarily the Optima Ultimate Street Car series, LS Fest Grand Champion competition, and other events like Midwest Musclecar Challenge.
I am keeping the nitrous, for use at events that have a drag racing portion/competition, and to still have some fun at things like Friday Night Lightz and Cincy Street Wars....
Engine
Drivetrain
Suspension
Braking
Exterior
Interior
Engine
- 416 c.i. LS3 short block
- Callies Compstar 4" crankshaft
- Callies Compstar connecting rods
- Wiseco -3.2cc flat-top X-series pistons.
- custom spec camshaft by Brian Tooley: 247/255 624/624 113+3 (designed for n/a + n2o optimization)
- Cloyes hex-a-just single roller camshaft sproket
- Katech C5R timing chain
- Melling 10296 high pressure/high volume oil pump; Ported and shimmed by RAFT Racing
- ARP main studs
- ARP head studs
- LS9 Headgaskets - TrickFlow 235 cylinder heads, milled 0.045" (11.98:1 CR) w/ powdered metal valve guides + some anti-detonation work to chambers (compliments of Brian Tooley)
- Brian Tooley Racing Platinum valve springs w/ titanium retainers
- COMP Cams hardened pushrods
- COMP Cams trunion upgrade kit
- LS7 lifters
- Holley valve covers, powdercoated red
- LS2 ignition coils
- MSD spark plug wires
- ATI super damper (10% underdrive)
- LG Motorsports Super Pro 1 7/8" long tube headers (no cats) - ceramic coated satin black
- FAST102 intake (port matched by B. Tooley)
- FAST fuel rails; limited production anodized black
- Siemens DEKA 60lb injectors
- Vararam VR-B2 ram air intake
- Vararam power duct
- Nick Williams 102mm throttle body
- MAF delete - oem IAT sensor installed in intake
- Racetronix harnesses including fuel pump hotwire harness
- Lingenfelter 2-step Launch Controller (LNC-003)
- RSD Line Loc
- Custom oil cooler setup w/
- B&M Supercooler oil cooler
- Improved Racing thermostatic oil cooler adapter - EFI Live tuned (Tracy Scott + Kevin Doe)
- Custom nitrous setup
- Nitrous Outlet 102mm Nitrous Plate
- Nitrous Outlet fuel & n2o solenoids
- Nitrous Outlet purge solenoid
- Harris Speed Works pressure activated bottle heater
- NOS Remote Bottle Opener
- NX Maximizer 4 Progressive controller (thinking of switching to the new NO progressive controller)
- custom fabricated fuel tank for nitrous system w/ walbro pump and aeromotive regulator, battery box mounted
- custom switch panel
- EFI Live COS5 o/s for nitrous tuning
Drivetrain
- Rockland Standard Tranzilla w/ ZR1 gearing and external cooler setup
- RPM Transmissions Lvl 4 differential with 3.90 gear and external cooler setup
- Driveshaft Shop carbon fiber driveshaft (TBD)
- McLeod RXT clutch
- Fidanza aluminum flywheel
- Pfadt diff mount
- Hinson motor mounts
- Tick Performance clutch master cylinder
- Tick Performance remote speedbleed line
Suspension
- JRi 2-way adjustable shocks, RAFT specs
- VB&P xtreme leafsprings
- RAFT tuned
Braking
- C6 ZO6 brake calipers front and rear
- Hawk DTC-70 single piece front pads, DTC-60 in rear (napa oe pads for street use)
- MidAmerica Motorworks stainless brake lines
- Castrol SRF brake fluid
Exterior
- Forgeline GA3R wheels 18x11 front, 18x13 rear
- BF Goodrich Rival tires 315/30 front, 335/30 rear
- TPE T2 flared fenders
- World Challenge front bumper (to be installed)
- ACP 2" front splitter (to be installed)
- C7 carbon side skirts (to be installed)
- 3M Satin Pearl White wrap
- ACA pop-up HID kit with 6k bulbs
- Black housing bumper lights w/ LED DRLs
- Tinted taillight & reverse light covers, tinted rear side markers and 3rd brake light
- shaved radio antenna
Interior
- MGW short-throw shifter
- MGW shift ****
- Arizen Racing leather racing seats
- Hardbar Harness Bar
- Simpson 5pt harnesses (stock seat belts also retained)
- Electronic antenna behind rear view mirror
- custom trunk separator
Still need to wrap up the drivetrain and aero... Then comes the suspension and will get an accusump to protect the motor until a Daily Engineering dry sump can be installed...
Received 19,299 Likes
'20-'21-'22-'23-'24
Damn, that car looks great. Nice bunch of mods you already have on the car. Be sure to post updates as you do more work.
Thanks guys!
You make a great product! I was very impressed at how easily those large primaries slid right in without having to do any antics with the motor/subframe!
Also seriously considering your GT2 wing to compliment my aero package.
The machine work and short block assembly was done by All In Racing Engines in Cincinnati. I got a partial sponsorship deal. Contact Jimmy at All In for a quote. Tell him Juicy referred you (could also use my name, but Juicy will give him a chuckle)
Received 1,679 Likes
Brother that is a great looking car! The wheels really set it off... Nicely done!
Former Vendor
Danny put the car together right? I have wings in stock, just yell at me or Danny when you want to pick one up. Shoot me an email and I can give you some install pics with it too.
Whoa, Honda based screennames with satin white pearl vettes....interesting...lol.
I'm supercharged, bolt ons, z06. Built the H brand for 10 yrs plus out of my shop in Pa.
Very nice, I like watching the Ultima shoot out on TV.
Had the TPE flares on for long?
How much power are you expecting to make? What are you doing for brakes?
I just installed the TPE fenders. TPE was great to work with. I know others have expressed concerns in the past, but I thought he was just fine. The time it took was longer than expected, but he stood behind his business and offered to cover shipping due to the delay, that was beyond his control. I would definitely do business with him again.
As far as power, I would guess around ~570whp on motor when I get it dialed in.
Need to figure brakes out. Stockers will work for these street car events, but really should step it up. Ultimately I will do what Danny tells me to do there, lol
That car is a BAD boy, very nicely done, one of the coolest C5Zs I've seen in a while!
How do you like those BFG Rival tires? I was thinking of those for my next set. I currently have Michelin PS2s, which are great all-around, but don't really have enough dry grip for my 555rwhp LS7. I used to have Nitto RIIs, which had great dry grip, but were very poor in the wet, scary at times if caught in a downpour. I was between these Rivals and Toyo R888s for my next set of tires. I have CCW wheels and run 275/35/18 and 315/30/18 sizes.
Thank you!
Thank you!
Z
Such a excellent choice in color and rims, flows really nice!! great job!! i have a C5 Z06 and C6 Z06, while I love the C6, the C5 is still a radical car!!love your build though!! favorite color besides black!!!
