[Z06] Very rough start up!! Help plz!!
Old 02-12-2014, 11:18 AM
moravette
moravette's Avatar
Default Very rough start up!! Help plz!!
So I have a 03 Z and lately with the cold weather when I start it up it revs up really high to about 3000 rpms then drops to about 500 rpms. It usually does this for awhile up and down untill the car warms up. I've already replaced the spark plugs and wires, cleaned the throttle body, and changed the TPS sensor. The check engine light is still on and last time I took it to get check it said the car was misfiring and I just replaced the plugs and wires that day. Could it be a coil pack?
Old 02-12-2014, 11:25 AM
Sox-Fan
Sox-Fan's Avatar
If the check engine light is on what are the codes?
Old 02-12-2014, 11:54 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
did u scan for codes (stored in pcm)?
Old 02-12-2014, 05:41 PM
moravette
moravette's Avatar
Just scanned for the codes and it's reading my MAS.
Old 02-12-2014, 07:47 PM
moravette
moravette's Avatar
Would it be best to try and clean the mas air flow first or just try and find a new one?
Old 02-12-2014, 07:53 PM
RedZMonte
RedZMonte's Avatar
What is the Code number? "P0XXX" Could be a damaged wire, could be a bad or dirty MAF, Could be a Vac Leak. You need to post the exact code number in order for us to help dianose.
I would allways try cleaning it 1st. also unhook the MAF and see if it smooths out. It will trigger the MAF code but will help determine if its the sensor. Obviously if you have a spare sensor try it. Do you have any way to "SCAN" the car? if so you can check to see if you have a reading for the MAF or if its 0, (should have a reading in Hz and will change with RPM's)
S
Old 02-12-2014, 07:56 PM
moravette
moravette's Avatar
I just took it to autozone and had them hook it up and check I didn't get the code but he was saying it could be a number of things but the MAF is what stood out. Also it was ready something about the ignition sensor but that could be caused by the MAF from what I was told
Old 02-12-2014, 08:38 PM
RedZMonte
RedZMonte's Avatar
you can pull the code yourself in the dash of a Corvette.
http://www.corvetteactioncenter.com/...-codes-c5.html
To Very rough start up!! Help plz!!
Quick Reply: [Z06] Very rough start up!! Help plz!!
