[Z06] Trans fluid options - Not liking Amsoil torque drive
Old 05-13-2014, 06:46 AM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Default Trans fluid options - Not liking Amsoil torque drive
I recently changed out my fluid with the amsoil torque drive product. I'm not happy with how the car is shifting after the fluid change.
What other ATF's are people using? What would the stock ATF be?
Old 05-13-2014, 06:47 AM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
This is for an 02 Z06, stock and used for track events
Old 05-13-2014, 12:39 PM
bada
bada's Avatar
Yea I tried it also. And then went right back, to the gm recommended fliud. I did not like it at all.
Old 05-13-2014, 10:30 PM
916Z06
916Z06's Avatar
Swapped out my trans fluid with mobile one and shifts like butter, way smoother. I like it and would recommend it.
Old 05-14-2014, 12:24 AM
84REDCROSSFIRE
84REDCROSSFIRE's Avatar
Pennzoil Synchromesh, been using it in my 02Z for years.
even buttery smoother than mobil 1, i tried that first
Old 05-14-2014, 06:36 AM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Thanks all, I've done a lot of reading on the topic. Seems like different cars and ATF all react differently. Lots of different experiences out there.
I think I'll try Mobil 1 next and go from there.
Old 05-14-2014, 10:57 AM
txst
txst's Avatar
I was in the same boat as you - the Amsoil was extremely notchy when cold. I went back to Royal Purple Synchromax. Seems to work fine for both street and track.
Old 05-14-2014, 12:24 PM
MY03C5Z
MY03C5Z's Avatar
Same here, shifts fine. Takes a minute of driving when cold though, first few shifts after it sits overnight are a little sluggish. After a minute of driving its fine though.
Old 05-15-2014, 09:16 AM
rjwz28
rjwz28's Avatar
Anybody who is running a fluid that meets GM's Synchromesh standards is out of spec for these cars, which explicitly instruct in the manual to use ATF and to NOT USE Synchromesh... I don't know why, but there must be a reason that GM was so specific about this.
Old 05-15-2014, 03:07 PM
RedZMonte
RedZMonte's Avatar
GM Fluid or Valvoline DexIII work good.
Old 05-16-2014, 01:44 PM
txst
txst's Avatar
Agreed. Royal Purple Synchromax is specifically for manual transmissions that use ATF.
Old 05-16-2014, 03:14 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Well, I was going to use Mobil 1 as the next fluid. I went to order only to find out they have "all vehicle" ATF for Dexron 3 and 6. I didn't like the sound of that.
I ordered Royal Purple Max ATF. On the bottle, it lists Dexron III as a replacement. In fact it was like Dexron III(g) and (h) or something along those lines. I couldn't find any reference on RP's site that synchromax was Dexron III compatible so I went with the MAX ATF.
I'll get it changed this weekend and let everyone know how it goes.......
This has been a very confusing topic
Old 05-16-2014, 03:52 PM
Socko
Socko's Avatar
I run redline d4. works fine, i drive my car anytime its not raining or salty. So it gets driven in the 3x degrees plenty and the trans shifts fine always. Shifts fine on the track after 20 minutes of beatings too. Never had an issue with it.
Old 05-16-2014, 04:19 PM
racebum
racebum's Avatar
also run redline d4, love it
then again, in general i always lean to redline over amsoil
Old 05-16-2014, 07:09 PM
rjwz28
rjwz28's Avatar
I'm not familiar with that product, but my comment was directed to the guy above you running Pennzoil Synchromesh, which is absolutely NOT for transmissions like the T56 which are designed to use ATF
To Trans fluid options - Not liking Amsoil torque drive
Quick Reply: [Z06] Trans fluid options - Not liking Amsoil torque drive
