[Z06] Wake Your Engine Up With A FAST Intake From Hinson Motorsports
Old 06-12-2014, 06:26 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default Wake Your Engine Up With A FAST Intake From Hinson Motorsports
The LSXR™ is constructed from a proprietary advanced polymer material which offers a host of benefits over aluminum aftermarket intakes, including lighter weight, strength and improved heat dissipating characteristics. While the LSXR™ features a 102mm air inlet that is perfectly suited for the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock or aftermarket 90mm or 92mm throttle bodies. Other features include integrated nitrous bungs and perfect bolt-on fitment that allows the use of factory accessories without modification or clearance concerns.
FAST LSXR 102mm Intake Manifold (LS1/LS2) <- CLICK HERE FOR PRICING & INFO
FAST LSXR 102mm Intake Manifold (LS3) <- CLICK HERE FOR PRICING & INFO
FAST LSXR 102mm Intake Manifold (LS7) <- CLICK HERE FOR PRICING & INFO
FAST LSXR 102mm Intake Manifold (4.8/5.3/6.0L Truck) <- CLICK HERE FOR PRICING & INFO
DON'T FORGET YOUR PORT SEALS!!!
FAST Intake Port Seals LS & LS2 <- CLICK HERE FOR PRICING & INFO
FAST Intake Port Seals LS3 <- CLICK HERE FOR PRICING & INFO
Inside the FAST LSXR 102mm Intake Manifold (LS1/LS2) As you can see from the pictures below the FAST intake has a SMOOTH tunnel deck unlike the factory intakes that are ribbed robbing horsepower and creating turbulence within the intake.
Old 06-18-2014, 10:55 AM
0HinsonSuperCars
Former Vendor
Thanks for the orders.
Quick Reply: [Z06] Wake Your Engine Up With A FAST Intake From Hinson Motorsports
