[Z06] August 2014 GM Parts House C5 Corvette GM Parts Specials!
Premium Supporting Vendor
Greetings All,
August is Corvettes @ Carlisle month and as always we will be one of the largest, if not the largest, tent on the Manufacturers Midway. If there is anything you'd like us to bring please contact myself or Patrick ahead of time. We will special order your items and bring them to the show for you to pick-up.
We will have all of the C5 Genuine GM Parts & listed below on hand and much more.
Again, I do ask if you would like us to bring anything specifically to the show to contact me, gene@gmpartshouse.com, or Patrick, patrick@gmpartshouse.com.
To order these items it is easiest to go to www.gmpartshouse.com and use the part number(s) given and/or send us an email or give us a call!
Thank you!
Gene.
||--Genuine GM Radio Surround Bezel--||
10407815 – Ebony – $312.39
||--Genuine GM C5 Ignition Switch Bezel--||
2852046 – C5 Ignition Switch Bezel – $16.52
||--Genuine GM C5 Door Panel Pull Plug--||
10279471 – Door panel pull plug (rectangular shaped ebony) – $3.15
||--Genuine GM 3 Piece Frt Spoiler/Air Dam--||
10401458 – Center – $133.34
10419312 – LH – $23.38
10419313 – RH – $30.56
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $276.74 total.
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on C5’s without modification.
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 (2) – Front stabilizer insulators
15241135 (2) – Rear stabilizer insulators
Complete kit front and rear is $230.39
Use part number c6z51bars on our website under Chevrolet make.
These sway bars do fit any C5 without any modifications.
This kit does not come with metal end links. If you want to add metal end links use part number 20822934 for $28.28 each.
GM has now updated all C5-C6 end links to the 2013 version.
||--Genuine GM Key FOBS/Transmitters--||
10253839 – 97-99 – See Note Below.
10432147 – 00 - See Note Below.
Both the 10253839 and 10432147 FOB’s have changed to 19299230. GM has changed both FOB’s into one part number FOB covering years 1997-2000.
19299230 – 97 – 00 - $91.00
25695954 – 01-04 #1 – $71.50
25695955 – 01-04 #2 – $71.50
||--Authorized Lloyds Mats Distributor--||
We are an authorized Lloyds Mats Distributor. We can customize floor mats specifically to your liking and have them custom made for you and shipped directly to you. Please contact Patrick, patrick@gmpartshouse.com for your floor mat quote today.
||--Genuine GM 97-00 Corvette to 01-04 Corvette TPMS Conversion--||
PKC5TPMS - $439.99 (Special Discounted Price)
This kit includes the following:
(1) #1 Key FOB
(1) #2 Key FOB
(1) Remote Control Door Lock Receiver
(1) Remote Control Door Lock Receiver Connector
(4) Tire Pressure Monitoring Sensors (TPMS)
(4) Tire Pressure Monitoring Sensor Mounting Nuts
This kit retails for $685.42 and includes everything you need to convert your TPMS and key FOB’s in your 1997-2000 Corvette to the 2001-2004 Corvette. This is done to change the future costs or current costs of the more expensive 1997-2000 Corvette TPMS and key FOB’s to the lesser expensive 2001-2004 Corvette TPMS and key FOB’s. Click on the link below to purchase.
http://store.gmpartshouse.com/partlo...subcat1=175054
||--Genuine GM C6 Z06 LS7 Clutch Kit--||
24255748 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are $469.99 total.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
We are now offering the LS7 clutch kit with the matching Fidanza 12.9 lb. aluminum flywheel.
Comes with LS7 clutch disc, pressure plate, alignment tool and Fidanza flywheel - $699.99
For the complete kit on our website, use part number ls7alumclutch under Chevrolet make.
24264180 - LS6 Slave Cylinder – $150.74
12564455 - LS6 Master Cylinder – $153.45
14061685 – Pilot Bearing – $14.89
*Clutch does work in any LS1/LS6 drive train but must also have ls7 flywheel.
Also, you can only use LS1/LS6 hydraulics, not LS7 hydraulics.
We now also provide a clutch alignment tool with the kit and the kit from GM does not come with this so we have added it for your convenience!
||--CTEK 3300 Battery Tender/Charger--||
56158 – CTEK 3300 Battery Tender - $59.99
Click below to order and for more information.
http://store.gmpartshouse.com/partlo...catalogid=7587
||--Genuine GM C5 Front End Cover/Bra--||
19202113 – 1997-2004 Non-Z06 Front End Cover – $84.00
Z06 front end cover is no longer available.
||--Genuine GM C5 Car Cover--||
19158333 – Car Cover (Gray with black “Corvette” logo) – $233.45
This car cover is a storm shield (outdoor) deluxe car cover.
It has sealed seams and soft lining for great indoor/outdoor use.
This car cover fits all C5 models from 1997-2004. No other colors available.
||--Helms Corvette Service Manuals--||
1997 Corvette Service Manual - Discontinued
1998 Corvette Service Manual - $195.99
1999 Corvette Service Manual - $295.99
2000 Corvette Service Manual - $295.99
2001 Corvette Service Manual - $295.99
2002 Corvette Service Manual - $195.99
2003 Corvette Service Manual - $195.99
2004 Corvette Service Manual - $295.99
2005 Corvette Service Manual - $195.99
2006 Corvette Service Manual - $295.99
2007 Corvette Service Manual - $195.99
2008 Corvette Service Manual - $225.99
2009 Corvette Service Manual - $225.99
2010 Corvette Service Manual - $225.99
2011 Corvette Service Manual - $225.99
2012 Corvette Service Manual - $225.99
2013 Corvette Service Manual - $225.99
2013 Corvette Service Manuals Currently Available - $225.99
Please Call Or Email For Pricing On Any Other Make/Model Vehicle
To order the service manuals:
Click on the link below and select your Corvette model year! Add to cart! Check out!
http://store.gmpartshouse.com/partlo...egoryID=178664.
If you’re interested in manuals for any other GM product send us an email or give us a call.
Contains Factory Authorized Service information written by General Motors. It contains Diagnostic Information and Procedures, Schematics and Routing Diagrams, Component Locator, Repair Instructions, Description and Operation, Specifications, and Special Tools and equipment. Service information on HVAC, Body & Accessories, Restraints, Steering, Suspension, Driveline/Axle, Brakes, Engine and Transmission/Transaxle.
||--Genuine GM C5 HUD Parts Kit--||
PKC5HUD - $329.95
This is a kit that we made up here @ GM Parts House to add the HUD to the C5. The kit currently includes the following items:
GM HUD Bezel
GM HUD Switch
GM HUD Projector
No Hardware Or Wiring Harness Provided.
Click on the link below to order.
http://store.gmpartshouse.com/partlo...subcat1=184248
||--Genuine GM C5 Tune-Up Items--||
12495519 – GMPP red spark plug wire set – $66.94
12621258 – GM AC Delco Iridium spark plugs – $6.97 each
10287788 – 97 & 98 fuel filter – $14.18
19239926 – 99 – 04 fuel filter/pressure regulator – $88.70
25042562 – 97 – 04 air filter – $14.13
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 – sensor – $53.00 each
15234846 – nuts – $5.19 each
Total setup of 4 is $232.76
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
1997-2000 Sensors
25981210 - sensor – $129.53 each
15234846 - nuts – $5.19 each
Total setup of 4 is $538.88
||--Genuine GM Sport Seat Foams/Pads--||
97/98/99/00
10273418 – D/S & P/S seat back outer foam – $49.96 each
10283891 – D/S & P/S seat back insert foam – $103.75 each
10273420 – D/S & P/S seat cushion foam – $127.00 each
Complete set of 6 seat foams/pads $561.42
01/02/03/04
10273420 – D/S seat cushion foam – $127.00
88991516 – P/S seat cushion foam – $82.37
Complete set of 6 foams/pads $516.79
||--Genuine GM C5 Corvette Emblems--||
19207384 – 97-04 Front bumper emblem – $87.64
19207385 – 97-04 Rear bumper emblem – $57.08
19207388 – 2004 Front bumper emblem (CE) – $176.47
19207389 – 2004 Rear bumper emblem (CE) – $129.06
19207386 – 2003 Rear bumper emblem (50th Anniversary) – $96.15
19207387 – 2003 Front bumper emblem (50th Anniversary) – $100.83
10315690 – Front fender emblem (50th Anniversary) – $166.44
10429629 – Front fender emblem (Z06) – Discontinued NLA
10314089 – Front fender emblem (Z05 405HP) – $49.86
||--Genuine GM C5 Belt Tensioners/Pulleys--||
12560345 – All C5 A/C Tensioner - $94.57
12557334 – All C5 A/C Idler Pulley - $41.86
12559325 – 97-00 – Serpentine Belt Tensioner - $87.63
12568181 – 01-04 – Serpentine Belt Tensioner - $79.53
12564401 – All C5 Serpentine Belt Idler Pulley - $54.26
||--Genuine GM C5 Fan Belts--||
19244950 – C5 Serpentine Belt – $55.81
19172680 – C5 A/C compressor belt – $56.30
These belts fit all C5 Corvettes from 1997-2004.
||--Genuine GM 2013 C6 Shifter Kit--||
25823572 – C6 shifter
25821873 – C6 shift ****
11571034 - Bolt
Complete kit $205.34
For this kit on our website, use part number c6shifter under Chevrolet make.
This shifter kit works on all C5’s. The C5 boot will either need to be modified or you’ll have to purchase an aftermarket boot for a C5 that fits a C6 shifter.
Note: The Z06 shifter has been discontinued as there were problems with rattling. There are no throw or height differences as the previous difference was bushings.
||--Genuine GM C5 Z06 Components--||
Z06 caliper set – $488.24 (all calipers total)
On our website, use part number c5z06calipers under Chevrolet make.
Z06 front screens – $263.59 (both screens total)
On our website, use part numbers 10424820 and 10424821 under Chevrolet make.
Z06 front brake ducts – $68.11 (both ducts total)
On our website, use part numbers 10295976 and 10295977 under Chevrolet make.
Z06 rear screens (scoops) – $189.08 (both scoops total)
On our website, use part numbers 10322761 and 10322762 under Chevrolet make.
Templates to cut out the rear scoops – Free!
http://www.gmpartshouse.com/template...mplate1of2.pdf
http://www.gmpartshouse.com/template...mplate2of2.pdf
Z06 rear brake ducts – $65.21 (both ducts total)
On our website, use part numbers 10425976 and 10425977 under Chevrolet make.
Z06 2004 shocks – $515.00 (all 4 shocks total)
For all 4 shocks, use part number 04z06shocks under Chevrolet make.
Z06 sway bar kit (insulators, bars and metal end links)
The C5 Z06 sway bar kit has been discontinued by GM. We recommend using the C6 Z51 sway bar kit instead. The C6 Z51 sway bars are just a tad larger.
Z06 front brake pads – 19181427 – $150.80
2001 – 2003 Z06 rear brake pads – 12530688 – $67.60
2004 Z06 rear brake pads – 19259589 - $94.90
Z06 rear differential assembly (3:42) – 12572683 – $1478.53
Z06 front suspension spring – 25962573 – $287.38
Z06 rear suspension spring – 22188038 – $623.47
||--SLP 160 Degree Thermostats--||
100223 - 1997-2003 Corvette - $54.99 (Comes W/Housing & Seal)
100228 – 2004 + Corvette - $22.99 (Thermostat & Seal Only)
If you’ve changed your water pump at any time you may have a new style water pump with a different style thermostat and you may need the newer thermostat part number 100228.
||--Hawk Performance Brake Pads--||
We offer the lowest advertised price for Hawk brake pads. Please call 484-949-2099 to order by phone or you may also order on the site by going to www.gmpartshouse.com and enter the part numbers below and be sure to select Chevrolet make.
Below I will paste links to the Hawk Performance site for you to get a better understanding of what the different compounds are. If you need further assistance, again please call.
HPS
http://www.hawkperformance.com/performance/hps.php
HP Plus
http://www.hawkperformance.com/performance/hpplus.php
Performance Ceramic
http://www.hawkperformance.com/performance/ceramic.php
1997 - 2004 Corvette
(All Models and All Brake Packages)
HPS Front - HB247F575 - $108.95
HPS Rear - HB248F650 - $79.12
HP Plus Front - HB247N575 - $136.20
HP Plus Rear - HB248N650 - $104.04
Performance Ceramic Front - HB247Z575 - $115.84
Performance Ceramic Rear - HB248Z650 - $80.14
||--Genuine GM C5 Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits $128.40
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets - $278.20
||--Genuine GM Crate Engines--||
19301326 – LS3 crate engine – $6,599.99
19244098 – LS7 crate engine – $14,299.99
19260165 – LS9 crate engine – $21,995.99
||--Genuine GM C5 T1 Engine/Suspension Items--||
T1 shocks – $769.16
T1 trans cooler – $1153.27
T1 sway bar pkg with insulators and end links – $901.02
T1 complete suspension package – $3287.87
T1 suspension springs - $953.82 each
For all T1 related items please call us for availability and to order.
||--Genuine GM LS2 Items--||
12602691 – LS2 bare block – $1135.99
89017648 – LS2 intake manifold – $349.09
12570790 – LS2 throttle body – $495.00
12633511 – LS2 fuel rails – $177.50
89017587 – LS2 injector o-rings – $33.25
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s - $91.95
12561503 - '99-'04 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'04 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s - $108.45
12564257 - '01-'04 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'04 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s - $136.04
||--Genuine GM Radiator Cage/Skid Plate--||
10400765 – Radiator cage – $384.11
To bolt everything to the cage you need to purchase the nut inserts below. These are threaded inserts that will allow you to bolt items to the cage. If you want to purchase new bolts you can purchase them as well.
11609836 – Nut insert – $3.11 (Qty 1)
11518908 – Nut insert – $4.91 each (Qty 7)
11570082 – Bolt – .95 (Qty 1)
11514623 – Bolt - $1.03 (Qty 7)
Note: Some of the hardware may show up on the website as fitting something else or another application. That is correct; they fit many other vehicles and applications.
||--Genuine GM Ultra Guard UPF 44 Oil Filters--||
25329389 - UPF 44 Oil Filter - $10.71 each
We will sell them in singles or case quantities of (6).
||--C6 Z06 Brake Upgrade Kit--||
Z06 brake upgrade kit - $2199.99
Kit includes:
Front & Rear Calipers
Front & Rear Rotors
Front & Rear Brake Pad Kits
You’ll need the proper wheels for clearance and you’ll need to purchase some aftermarket stainless steel brake lines for hooking them up. That is all you’ll need.
Use part number c6z06brakes on the website to order this kit.
||--Genuine GM Cylinder Head Bolts And Gaskets--||
12617944 – LS1/LS2/LS6 Round Port Header Gaskets – $12.64 each
12498543 – 97-01 LS1 Engine Head Gaskets (2) – $51.91
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – $36.88
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – $27.33 per head
17800568 – January 2004 – present LS1/LS6/LS2/LS3 Head Bolts – $27.33 per head
12589227 – LS2 Cylinder Head Gasket – $39.35 each
If you’re not sure which head bolt kit to use please email us your VIN# and we’ll tell you.
Thank you!
Gene.
(1) #1 Key FOB
(1) #2 Key FOB
PKC5HUD - $329.95
GM HUD Bezel
GM HUD Switch
GM HUD Projector
2001-2004 Sensors
1997-2000 Sensors
97/98/99/00
01/02/03/04
11571034 - Bolt
HPS
HP Plus
Performance Ceramic
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
T1 shocks – $769.16
Both FRC’s - $91.95
Kit includes:
Front & Rear Rotors
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
I'm in the process of ordering parts to upgrade my 03 C5Z suspension. I have bilstein sport shocks on hand, and wanted to change out to the redesigned metal end links - do they come as a pair or single pieces? How many do I need? Do you offer a end link/sway bar package?
