[Z06] Vibration with monster stage 2 questions
Just installed with new slave, master, pilot, and billet steel flywheel. I'm getting vibration through the gears and a lot through the shifter. Is this a common characteristic of this clutch. It's a single disc and was installed through a reputable shop. When put in neutral it stops the vibration. Will this cause an issue with anything internal in the motor until it's fixed? Thanks
Supporting Vendor
Received 1,012 Likes
NO that is not normal.
By vibration do you mean chatter? as in when you take off from a stop it vibrates around (aka chatter's)?
On a personal note We love Monster Clutch co. They offer a extreamly high quality product at a great price point and back it with exceptional customer service.
OP can you be more descriptive.
I notice the vibration the most say rolling in 3rd or 4th 40- 60 mph. You can also feel it Ina neighborhood going slow. The car also vibrates on decel. If you push the clutch in the vibration goings away or if you just put the car in neutral that takes away the vibration also. The shifter vibrates a lot but it also smooths out when the clutch is pushed in or in neutral.
This does not sound like an imbalance issue. The OP says the vibrations stop when he is in neutral or the clutch pedal is depressed (disengaged). If it was balance related, the vibration would continue on in either of those instances.
Here's more specifics, sitting still, if you rev the car and stay under 2k rpms, it's smooth. Any revving at or above 2k the vibration begins ans never stops. While in gear, if your under 2k rpms it's smooth, above 2k vibration starts along with a bunch of shifter vibration
You might be in trouble
Hi JChastain,
Please read the thread in the link below, the last one I documented with pictures from my PhotoBucket back in 2008, the answer to your engine issue is inside:
https://www.corvetteforum.com/forums...-balanced.html
Hope you kept your old clutch assembly.
Christian
Hi JChastain agai,
You will find testimony of the resolution of a similar issue to yours by Bill Curlee in the thread below:
https://www.corvetteforum.com/forums...-flywheel.html
Good luck
Christian
Thanks for the info Christian. My installer has communicated with monster and looks like a balance issue with the flywheel. So it also looks like monster is not standing behind their pre balanced product also. Will update if this situation changes.
Monster balances to zero. GM balance-matches these flywheel/pressure plate assemblies to the ENGINE. Monster has no way of knowing what your specific ENGINE balance is, so they provide an assembly balanced to ZERO. Monster has no responsibility for any problems regarding the relationship of the balance of your flywheel/PP to that of your engine.
2001/2002 LS engines internally balanced...
NOT APPLICABLE HERE as JChastain installed an LS2 Engine in his car...
Hi Everyone in this thread,
Some LS6 Engines from the end of 2001 to mid 2002 at least were externally balanced...
It was the engines that were assembled in the GM Canadian power plant if memory serves.
Those short-blocks are traceable with your VIN # as long as you still have the original engine coming with your car.
I had one of those!!!
My OEM Flywheel (saved carefully) in the picture below is showing ON THE EXTERNAL PERIMETER OF THE OEM FLYWHEEL the balancing from the GM factory with the Dowel Pins finally adding some extra weight.
I used it every time a new clutch went in for the MATCH BALANCING:
48 grams off balance is were is my OEM clutch assembly was.
The first time I had my GM OEM clutch replaced by with an assembly ZERO BALANCED the vibration was so bad between 2700rpm and 5200rpm that is was making the car barely drive able...
ALWAYS check if DOWEL PINS are present in your OEM Flywheel, consequently if your OEM flywheel is zero balanced or is off balance for external balancing purpose.
Quick, simple and efficient.
Christian
Christian
There are MANY more than just those years that are affected. ALL LS engines that were to be used in MANUAL transmission corvettes were taken through a final hot balance procedure, had FW AND PP installed and checked for total engine assembly balance, then added balance weights to the FW and/or front Damper as needed. This includes LS1/2/3/6/7/9 that were going to be used in MANUAL transmission vettes. Automatics were not affected. So the years go from 1997 to 20013. Any MANUAL vette in those years could have a FW with externally added balance weights in them from the factory.
Just a little distinction. Dowel pins in the FW protrude from the surface and are used for alignment only. Balance weights are installed in any of the 12 perimeter through holes on the FW, and are flush to below flush from the surface. The only way to tell if they are present is to try to "look through" the holes. Matching the FW only to original factory piece is only half the equation. GM installs both the FW AND the PP before hot balancing, so weights added to the FW are compensating for cumulative imbalances from all components; the internal engine, the FW, and the PP.
And finally, this hot balance was done for NVH purposes ONLY. The engines are fine AS ASSEMBLED. Manual transmission corvettes are more sensitive to slight imbalances and therefore GM balanced them down EVEN FURTHER to zero, past their normal balance tolerances, in order to minimize unwanted vibrations.
Christian
Christian
I'm curious as to how the shop determined this to be a balance issue. OP said that vibrations went away, or significantly decreased, when the clutch pedal was pushed in, or the car was in neutral. FW and PP are spinning in those cases, an imbalance in either would be felt then as well.
Just another simple, straightforward, routine clutch replacement for a manual corvette.
Former Vendor
As the owner of Monster I shot an email to the guys at LSXperts this morning on this issue, Charlie should be contacting you shortly.
We were told the engine was not the factory engine so the hot balance is out the window. That said, all our units do come balanced and it's not the flywheel that would be the issue but the pressure plate. FedEx can, from time to time, be rough with the units during shipping and balance issues, although few and far between, can happen. I told Charlie to pull the clutch, take it to a balance shop, and see what the status of the balance is. If it's out of spec I'll pay for the balance and the labor and I will get with FedEx on paying us back.
If you have further questions just contact me directly at Steve@MonsterClutches.com.
Former Vendor
Thanks for the technical data!
