[Z06] Getting message Service active handling, ABS, and traction control
Like the title states, in my 2004 Z06 after I get passed 10-20mph the service active handling, ABS, service traction control lights come on. When I shut the car off and turn back on they go away until I start driving again. It will idle all day long without throwing the lights. I pulled the codes and it spit out a laundry list of codes. They are:
C1221
C1222
C1227
C1234
C1235
C1248
C1255
C1278
C1293
C1295
All codes have the H for history behind them. When it first had it's problem I was rolling down the freeway at 70mph. Now it does it every time I pass 10-20mph.
Any thoughts as to what might be wrong? Car still seems to drive good. Brake pedal feels normal for the most part. Maybe a little softer then I'm used to. I noticed the master cylinder seemed like it's lost some brake fluid and there was a mysterious wet spot under the car the day before all this happened. Spot I think was brake fluid.
I really want to take the car to Mid-Ohio for the 10/10ths track day sept 29th so I need to get this problem figured out soon. Thanks for all the help!
Shane
C1221
C1222
C1227
C1234
C1235
C1248
C1255
C1278
C1293
C1295
Shane
