[Z06] Exhaust is loose issue
I can't figure out why one side is hanging lower and has movement. The first mount I see from the rear is the one with the springs. Can it be that the spring is worn out?
https://www.dropbox.com/s/nzinx8cbc0..._3840.MOV?dl=0
Look at the bushings where the muffler hangs under the rear bumper. On of mine is worn out and let's that muffler move around and droop lower. racecar=safety wire fix.
