[Z06] What should my next power mod be? list inside
Current set up :
Stock Crank/ Rods
Mahle Forged pistons (oem size)
Stock 243 heads intake/exhaust gasket ported
Competition Cam Custom grind Camshaft
Competition Cam Pushrods
Competition Cam Valve springs/ Retainers
Yella Terra 1:7 Ultra lights Rockers
ARP Head Studs
Stock Intake manifold
Blackwing Intake
Stock injectors that have been flow matched to 38 lbs
Melrose long tubes, hi flow X pipe with cats into SLP loud mouths
Seeing 420whp on 91 octane.
Supported Spec stage 3 clutch and light weight flywheel with Hurst short shifter.
What should my next step be ? Cost effective wise?
Stock Crank/ Rods
ARP Head Studs
Blackwing Intake
Are you running an effective tire to put down that power?
I dont think those ported FAST intakes are worth the $$.. I've seen 10-15rwhp gains on average.... for $1000+..
How about a 3.90 gear?
Cam specs are as follows :
"From the previous owners findings at least "
.591 lift exhaust
.348 lobe lift
.583 lift intake
.343 lobe lift
293 degrees exhaust
283 degrees intake
