[Z06] Ticking revolution sound from passenger front wheel
Car is an 01' Z06 with 28k miles on the clock. The passengar front wheel has a ticking sound only when the wheel is turned. From what I can tell it does it either way you turn the wheel. My first guess was the bogart center cap. I removed the wheel, repositioned, then torqued back down. The sound went away for a few miles, then started back put its much quieter now. Is a wheel bearing a possibility or are the miles too low? Or is it the cap? How do I fix this? Thanks
Had the same exact problem and only happened when I was turning. I was told to make sure I wasn't over/under torqued. I torqued the lugs to 100lb/ft and the noise has not came back. Hope you figure it out. It drove me nuts when it was happening to me.
Pro Mechanic
I know you meant 100 lb/ft...just wanted to clarify so OP doesn't watch his wheel fly off into the weeds!
