[Z06] Water pump removal...how bad?
So I took the ol girl (02CZ) to town and she was just loving the cold weather today. Ran her pretty good in the upper 5k - low 6k rpm range through a couple gears but didn't flog it to town and back. there were no puddles or dribble trails anywhere till I parked it at home. went back out the garage and could smell hot antifreeze. looked under the car to about a 1/8th of a gallon on the ground. looks to me like its the rear seal behind the water pump or I just blew up the WP....how difficult is it to change this? looks like there is a lot of stuff to remove.
it's easy, you will also want to replace all the hoses when you're in there. good chance to clean the radiator too. do not over tighten the WP bolts
list of all your part numbers in the cooling system and aprox. prices, there is probably a lower cost hose for part # 10229491 by dayco/goodyear etc. also buy your 5/8" heater hose somewhere local and get the smallest 5/8" they have, bring a caliper, some measure 9/16 which is what you want, some measure TTS at 10/16 or large at 11/16, you don't want this
Ac delco 20889 radiator $188.16
Ac delco water pump 251-744 $177.61
Ac delco water pump inlet w/ stat 15-11057 $29.30
Ac delco 18021L hose $27.52
Ac delco 24388L hose $25.35
Ac delco 24458L hose $14.59
GM hose 10229491 $24
Gates 18127 $12.62
Gates 5/8” heater hose {runs small} 2ft section
GM coolant tank 10430189 $69.95
Gates 18127 $12.62
It's not a bad job. It'll take you longer to drain the radiator and clean up the mess from disconnecting the hoses than the actual replacement of the pump will take.
there's one hose clamp that's a bear if you don't have cable hose pliers too, might be the upper one, can't remember, just remember trying all kinds of nonsense to get it off and wondering why i have never bought cable hose pliers. was hard to get conventional tools on it
Thanks for the reply guys... just for effect. here's how bad it is. runs at a trickles pace. Id load a video, but the forum doesn't support quicktime:/
you can upload videos to youtube and link that way
fix it before it gets worse, you also will need to replace your belts and really clean the pulleys, if they aren't squealing now they will soon from slipping on the coolant
theres no doubt that it has to be fixed. it wouldn't make it a mile without over heating and damaging the engine. im not sure how I didn't have a trail down the street or puddles else where. This is not a daily driver so it sits where it does till its fixed. parts are on order and should be here Thursday. already have another belt ready so just a cleaning and radiator hoses to be changed and I will be back in business.
make sure you use some purple power, dish soap etc and scrub the hell out of the pulleys, then hose the bejesus out of them, let them dry, then install the belts. do this step last as you will get coolant on stuff changing the pump and hoses
i wasted 2 belts my first time doing this job before i realized how sensitive these engines are to belts and contamination - slippage
the good thing is that it only started leaking after I shut it down. there is not any antifreeze on the belts, just on the crank pulley. I have the main belt guess I only need the A/C belt and a little cleaning.
Ok got the old pump out... What a pia! Biggest mess I've ever made changing a WP. Lol. I got to looking at this and I can't find where it was leaking. All seals look ok and opened the pump and all was working. Got the other parts off it and On to the new WP... Any famous last words before I install?
Received 1,261 Likes
now you see why i said to clean the pulleys so well, makes a giant mess
also blow out your radiator while you have this apart and easy access with an air blower
OK heres the pumps...what a difference. wonder why the new one is sealed and the old WP is serviceable? still cant find where the pump seal failed. there was a little moisture on the left side from the rear of the pump but no signs of a blow out...hope is not the seal on the intake! digging deeper this evening.
if you filled the pump up with water and added 15psi of air, then spun the pulley you may see it
if you can't do that, it's just a reasonable guess.
water pumps at this age are a very common failure item, VERY
Houston, I have a problem. new WP IDA is smaller than the stock WP IDA opening for the Thermostat...I ordered stock replacement parts and this is what I got.
my bad I must have over looked that...ended having to go to the Stealership today and for the correct one it cost me damn near the cost of the pump. $78 later im back on the road looking for birds and ponies for lunch.
now its time for a complete engine bay wash down with a heated pressure washer and some degreaser before winter hibernation.
interesting, so with the delco pump you listed above the original thermostat/housing won't fit?... my pump is off right now while I'm doing some other things and I considered replacing it just for good measure since it's kind of a pain to take off now having a blower in the way but I don't really want to have to buy a new thermostat and housing, mine is almost brand new anyway... I noticed on rockauto they have 2 delco pumps, one with the housing already installed which is cheaper (252836) and a more expensive one that doesn't include the housing (251744)... I was going to buy 251744 and reuse my thermostat
