[Z06] C5 z06 stock exhaust system $1000
Received 1,261 Likes
good luck
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
150-200 is the going rate - I tried to sell mine when I put the new exhaust on. I still have the stock exhaust manifolds - someone bought the mid pipe for 150.00. It was on craigslist for awhile before anyone was interested.
Some shops will buy the cats if you want to cut them out
To be 100% honest, If you are selling just the manifolds, mids, and H pipe minus the catback. There is no difference between what you are selling and a base C5 Coupe. With that said! you will be lucky to fetch $75 bucks on a good day.
IF YOU ARE SELLING THE FACTORY TITANIUM CATBACK EXHAUST. You are probably looking at 275 low-450 Max depending on miles and condition...
the 01 cat system was the worst though, this is the one year of 4 cats, in 2002 they moved to just 2
No no no now this is good for anyone simply trying to get back to stock...
If said person also needs the stock air intake, I will sell mind for $600 dollars. I'll autograph it for an extra $400. Oh I also have stock wheels and tires: $5,000.
The cat system was different from 02-04, 97-01 had pup cats... regardless of coupe or Z06
Who told you that lol, 01-04 C5/C5Z manifolds are exactly the same, No difference whatsoever... Now 01-04 manifolds are a little thinner then 97-00 but as for the Z06 manifolds being different on their own, they are not. It was a general change on every model from 01-04 not just the Z06!!!
Nah, the 97-00 Manifolds physically are identical, They are just a tad thicker and a little heavier, flow capabilities are the same as 01-04 which are a little thinner on the casting and lighter. Not much though.... The only tubular manifolds are the C6Z's.... You may have mistaken the heat shield on them for being tubular...
i just remember the GM marketing in 2001 touting the manifolds as being better or different. could have been just marketing
i knew the cats changed for the better in 02 and were less restrictive but i thought there was some manifold change along the way...obviously could be totally wrong since i've never worked on a c5 that wasn't a z06...oddly enough
maybe that was it
