[Z06] wheel firment?
Old 10-23-2014, 03:08 PM
Stroker87
Stroker87's Avatar
Default wheel firment?
Hi
I have an 03 zo6 what is the correct offset for the front and rear?
I'm looking at the set of rims with these specs but the guys said they will not fit a zo6 only a base model c5
FRONT WHEEL SIZE: 17x9.5
FRONT WHEEL OFFSET: 54
REAR WHEEL SIZE: 18x10.5
REAR WHEEL OFFSET: 56
BOLT PATTERN: 5-120.65
HUB SIZE: 70.3
Old 10-24-2014, 02:33 PM
john8642
john8642's Avatar
Front is 17X9.5 54mm offset
Rear is 18X10.5 58mm offset
There's a chart on page 8 of the thread below that shows the offsets for different wheels. There's also good information on how to measure the offset you need.
https://www.corvetteforum.com/forums...-thread-8.html
Old 10-25-2014, 05:57 PM
Stroker87
Stroker87's Avatar
so 2mm difference dont fit the ZO6?
Old 10-27-2014, 03:05 AM
john8642
john8642's Avatar
If you don't have the correct offset, the wheels will either stick out from the fenders, or be too far inside them. If they're inside, you can use a spacer to get the right distance. If they're outside, it won't look right. Depends on how particular you are. You can probably find out which it will be by reading the link I posted above. Is there some reason you need to have this exact set of wheels, as opposed to buying some with the correct offset?
Old 10-27-2014, 08:15 AM
ZF Six
Support Corvetteforum!
ZF Six's Avatar
Those will fit fine.
There is no difference between a base C5 and a Z06 as far as wheel fitment goes.
Old 10-27-2014, 10:13 AM
Stroker87
Stroker87's Avatar
I just found a set that I really like and a great price, I dont want it to stick out not my style but with a 2mm different would you really be able to tell?
the link was a little confusing for me
Old 10-28-2014, 08:38 AM
ZF Six
ZF Six's Avatar
You won't notice a 2mm difference.
My rears are 19x11 +55mm and they don't stick out.
Old 11-03-2014, 04:22 PM
Stroker87
Stroker87's Avatar
just made a purchase
17x9.5 front 18x10.5 rear wrapped in 265-40-17 & 295-35-18 Bridgestone Potenza RE760 now just need to wait 7 to 10 days and get c5 flags for them in red
To wheel firment?
Quick Reply: [Z06] wheel firment?
