[Z06] Buy HINSON Plug Wires & Heat Boots Get Free NGK Spark Plugs
Former Vendor
Hinson Motorsports is proud to offer these new Super Conductor 8.5mm wires. Made in the USA from a 8.5mm spiral core that matches MSD Wires 50 ohm per foot.
Heres How You Get FREE NGK Plugs:
- Add HINSON Standard Length Plug Wires to the Cart
- Add HINSON Plug Wire Heat Boots to Cart
- NGK TR-55 Plugs Will Automatically Appear for FREE
- Checkout
Standard Length 8.5mm Wire
Hinson Motorsports Plug Wire Heat Boots
Pair Your Hinson Motorsport Plug Wires with NGK TR-55 Plugs
Former Vendor
If you need NGK TR-6 plugs instead, please go ahead and purchase and specify the plug change in the notes section.
Former Vendor
These will definitely help with problem you are having. The boots are designed to withstand temperatures up to 1200F. We have put these on a lot of car and trucks since our recent release and had nothing but good results and reviews. I wouldn't recommend just letting them lay on the headers for obvious reasons but they will withstand bumping and direct hits as well as the overall radiant heat that the headers will put off. The long and short of it is they will definitely be better than nothing and help prolong the life of your wires.
