[Z06] "Square wheels", what tires?
Those of you running four 10.5 X 18 OEM Wheels . . . . For year round (no snow) use, what tires are you running? Feedback?
I am in LOVE with this setup. The tires are amazing, and the 18's in the front are absolutely awesome.
Doing a StopTech 6 piston BBK on Thursday, and Bilstein DRM shocks when they arrive later this month. A little lower and an alignment...and I'll be set
Well, now that they're available in 265/35-18 and 295/35-18, you can run those sizes, but before those were available, 255|285 was the only way you could run them if you wanted the factory stagger. 255/35s will fit on an 18x10.5, but if you don't want ANY stretch, you'll probably not like the way that looks.
I had 285s on 10.5" rims on my former Cobra and they pretty much went to the rim edge and looked good. I wouldn't go 275s as I the rim would be exposed and even a curb protector ridge on the tires likely wouldn't help prevent curb rash.
You might be pushing it up front regarding brake duct clearance at full lock, otherwise that should be a great setup double-check with the autocross and track guys, that's a common setup
I'm currently running 275-35 & 315-30. Michelin PS2s that I got from Charger21 who posted earlier in this thread (thanks Tom, I'll never be able to thank you enough for these great tires!!).
I love the tires and performance I get from them. As a bonus my fuel economy has improved a bit as well. The 275s up front look just a tad stretched to me, but, not bad. These should last me for a good while and I'm hoping that the PSS tires will have some good sizes available for me to use when these wear out!
Agreed on needing the meat in the back. The 315s have been great back there and the traction control almost never kicks in now.
The 285s should be great up front and I think those will fit without any interference.
