[Z06] Transmission
Transmission
I had installed a rebuilt transmission for my c-5 z-06. From a dead stop when you put it in 1st gear it will occassionally pop out of gear. Is this a linkage issue or other problem?
That's not normal. It could be your shifter. You need to adjust the shifter by moving it a little so it goes into 1st a little more and that should keep it in gear.
